Winter Massage @ Buckhead Imports Performance
#276
Actually haven't seen that Craig. Where did you source this info. Desperately need representation for a reputable Merc tuner here. Most of the local tuners are BMW/VW focused. I've been importing a loads of stuff - DCT/EC/TTM. Learning loads from you boys
#277
SPONSOR
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
#278
-Tools needed-
The rings/sleeves were custom made for the drilling and pinning, and the pin is in the very snug. It is not going anywhere, as it is secured by the head of the crank bolt which is tq'd to factory spec.
We decided to use the factory woodruff key in the stock keyway on one side, and pin 180* across from that on the otherside as an fyi.
