rough idle
Rating: Thread Rating: 3 votes, 5.00 average.
Old Jan 13, 2012 | 04:26 PM
theeddie's Avatar
e55 w/LET TUNE Drinks: vodka STRAIGHT Wheels: 19" HRE 547r Mods:FF headers ASP Pulley
rough idle
i have a buddy whos car idles very rough. the car will drive fine, but it feel like a cammed mustang at a light.
i think i checked all the hoses. i ran the smooth idle log in star and it shows all the cylinders as rough
any ideas
Old Jan 13, 2012 | 04:41 PM
02S430's Avatar
W220 M113K
any ideas
how many miles? have you checked you engine and tranny mounts? if you have high miles did you change your plugs and wires? have you changed your air filters regularly? might have a dirty MAF sensor
Old Jan 13, 2012 | 04:53 PM
cahiil55k's Avatar
Mine does the same thing, though very rarely. It usually happens on a 70* day, moderate humidity, and after a 20 mile highway cruise with no traffic. There is no CEL. I haven't datalogged it yet and am waiting to have my wideband o2 sensor installed but will let you know if I find anything. It's not the transmission or engine mounts for me - the car actually feels like it is going to shut off while stopped at traffic lights. It always goes away after I park and shut her off for 10 minutes or so.
Old Jan 13, 2012 | 04:57 PM
theeddie's Avatar
100000 miles never did plugs and wires was my next move but kind of pricey for him
tranny mount is brand new
ill check the filters
and im pretty sure the e55 doesnt have a maf
Old Jan 13, 2012 | 05:00 PM
02S430's Avatar
W220 M113K
ever change your fuel filter? your injectors might be dirty
Old Jan 13, 2012 | 05:03 PM
02S430's Avatar
W220 M113K
sorry forgot it has no MAF, autohaus az has the wires for $170, not sure about the plugs but that might be the problem if its not the mounts
Old Jan 13, 2012 | 05:58 PM
cahiil55k's Avatar
Good advice. I almost changed my fuel filter last year but since it required replacing more than the filter itself (have to change the entire fuel sender if I recall correctly) I opted to not do it yet because it wasn't showing any signs of wear or damage. I'll have my tech research if becomes more frequent.
Old Jan 13, 2012 | 06:59 PM
02S430's Avatar
W220 M113K
no prob, lets us know what happens
Old Jan 13, 2012 | 08:00 PM
berti_00's Avatar
2016 Cls63s AMG
spark plugs and wires and your back to like new
Old Aug 19, 2013 | 03:20 AM
majid3's Avatar
E55
I was told stalling at lights could be Idle Control Valve, Over £1000 from UK MB dealer but removal and clean may resolve the issue.
Anyway service was due and I had already ordered all the parts Oil filter from MB and all other filters from Euro Car Parts (UK Indy Company). So maybe try the service and ICV clean.
BTW i had P0-301, P0-302 to P0-308 fault codes too. These are cylinder misfiring codes and the end number relates to the cylinder number i.e. P0-301 cyl no1. But they all dissapeared after the Launch diagnosis reset the fault codes.
Really I need to diagnose with Star machine then service and clean ICV.
Old Aug 19, 2013 | 11:40 AM
Critter's Avatar
07 E63 + 07 CLK63CAB
Clean the throttle body, throttle plate and inner barrel.
To check , remove intake hose going into throttle body, turn on key, have someone depress the throttle which should open up the throttle, use finger to wipe the back side of the throttle plate which is actually the top side. Look at finger should be covered in black sludge. Using a clean rag and a tooth brush soaked in intake and choke cleaner clean the inside of the throttle barrel and the backside of the plate. For those more adventurous people, remove the throttle body all together and clean it completely.
You will be amazed at the grime that accumulates on the throttle plate which greatly affects idle quality.
Old Aug 19, 2013 | 07:35 PM
bstudey01's Avatar
2003 E55 AMG
This sounds like the dreaded 82mm TB swap issue. Mine does the same thing, I have tripped a code though but not always. The issue has to happen 3 times in a certain time frame before it will actually trip a cel. Have you noticed a very slight hiccup while driving on the highway usually upon light acceleration up a hill at about 70mph? Once you get the wideband watch your STFT's while driving on the highway. My car will hiccup, then stft's max out to +25%. A simple restart always fixes it too. I think there are many others with this issue, I wonder if the OP is modded???
Old Feb 29, 2016 | 06:36 PM
Bandit's Avatar
Check the intake manifold gaskets. Easy fix and a common problem on this generation E63.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
