Weird/ Burned smell under the hood
Drove 2 miles down the street to lowe's as planned. Convinced the smell was not exhaust-related, I kept my OBD adapter plugged in during the drive to check for codes but nothing popped up. Got out the car at lowe's and could smell a hint of the burned smell. On the drive back, hooked up OBD adapter and did a few hard pulls from 0 to ~35 just to get the IAT's to creep up and check recovery (thinking maybe my pump or wiring is the cause) but IAT's recovered quickly so pump works.
Got home, parked in the garage and could pick up the smell a little bit. Finally brought up the voltage screen on the dash and bam, 11.6-7V readout as opposed to the usual 12.1 with the car off. "Well that's odd yet timely" I thought to myself since I have had the weirdest inclination to replace my main battery as preventative maintenance (planned on buying one this coming Friday). Started the car and the voltage stayed at 11.4V as opposed to usual 14.1V. So I popped the hood and took another sniff around SBC and the smell was there but faint.
Turned the key to position 1 and 2 with no change in smell.
Cranked up the car (which took a few seconds -which is unusual) and now the smell got stronger still from the area around SBC. Battery voltage gradually dropped and the convenience battery blah blah message popped up together with the red Brake error on the dash. Revved it to 800rpm and as the voltage climbs from 11.4 to 11.6 ish, messages went away. Finally after a minute or 2 of idling, convenience features message comes up and this time with Brake warning, ABS and ESP messages. Voltage readout was in the 10s now so safe to say I'm 4kd at this point.
Cut the car off and saw 9V on the dash. At this point I am guessing my alternator has failed or something inside of it. Picking up the new battery anyways at Advance tomorrow in the AM and either driving the car or towing it in to the dealership (14 miles away). I already have a couple of minor things I want warranty to replace anyway so timing isn't too bad.
Has anyone had such an encounter? I've read numerous posts from failed batteries to people replacing alternators to battery control modules. Where is the BCM located and to those that had failed alternators, what at all was involved and did any of you guys have any of these symptoms. All this happened just this past evening for me with no prior incidents.
May want to check that out first before spending the $ for a new alternator.
I have one really cheap. New In Box OEM
best of luck
Just ordered one...
