Rebuild Project E55 Wagon
#59
PLATINUM SPONSOR
Acid,, Wow!!!! That motor sounds insane!!!!!!! You can tell that motor is pumping some serious air!! Great videos and install pictures!!
Your dash is shocking to see in so many parts!
Ok, what is next and when????
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
#61
Still got lots to do. Jerry will map the car and it should be driving tomorrow,
Need to run the engine and be ready for the vmax event end of the month.
Acid
#71
