82mm Throttle Body for E55 AMG 2004
Old Jan 23, 2012 | 12:03 PM
alsokihi's Avatar
E55 AMG 2004
I want to ask for 82mm Throttle Body
Does it have a negative effect on the engine? Will need to modify the car computer after the installation piece on the engine or not the need for that
What are the companies approved to buy this product from them and at a reasonable price, thanks
Old Jan 23, 2012 | 12:10 PM
grantwoodtx's Avatar
GLE 63S
STFF
Old Jan 23, 2012 | 12:11 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Old Jan 23, 2012 | 12:15 PM
BlkE55K's Avatar
2010 E350, 2011 ML350, 2003 996TT
Yes, you will need to open the ECU and remove the capacitor at location C15. Then, you will need to make sure you attach a fan to the ECU box because the 82mm TB will make it really hot. It's kinda like overclocking a computer.
Old Jan 23, 2012 | 12:33 PM
alsokihi's Avatar
E55 AMG 2004
Walton has been added 180mm Pulley and Tun a month ago was to modify the file after the installation and dyno work and now I would like to add 82mm Throttle Body .... Do I need to modify the electronic unit again?
Old Jan 23, 2012 | 12:36 PM
alsokihi's Avatar
E55 AMG 2004
Has been added 180mm Pulley and Tun a month before the file was modified after the installation and dyno work and now I would like to add 82mm Throttle Body .... Do I need to modify the electronic unit again?
Old Jan 23, 2012 | 01:12 PM
GLE 63S
OMG a newb quoting himself!
LIKE I SAID STFF!
Old Jan 23, 2012 | 01:38 PM
BlkE55K's Avatar
Yes, capacitor C15 removal and attaching a fan. Some people run some tubing from the aux fan in the engine compartment through the firewall and have the ECU sit on a velocity stack so it cools enough. If you want to be safe, put a heatsink on the outside of the ECU unit as well.
Old Jan 23, 2012 | 02:20 PM
Jimshorts's Avatar
'05 SL65, '13 FX4 Eco
