clunk
Old Jan 24, 2012 | 01:43 AM
theeddie's Avatar
e55 w/LET TUNE Drinks: vodka STRAIGHT Wheels: 19" HRE 547r Mods:FF headers ASP Pulley
clunk
first new motor mounts new tranny mount (ac is no longer hitting the sway bar)
i have FF long tubes
when i give the car gas i get a scraping sound from under the car, feel like under the floorboard drivers side but not always
i also sometimes get a sound when turning left and giving the car gas
any ideas?
Old Jan 24, 2012 | 08:21 AM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
You're headers could be coming into contact with your steering shaft.
Old Jan 24, 2012 | 09:58 AM
MBTEK's Avatar
06 E55, 03FORD P/S,01 E320-4M,99 ML320,O4 E55,05 RUBICON UNLIMITED,
I would suspect either one of the left side header tubes is contacting the steering shaft as stated or the ex. pipe is hitting the trans cross member. I have had to correct both those problems with FF headers after replacing engine mounts on a few E55's. I heated the down pipe that was contacting the shaft then made a small radius relief in it to clear. On the trans cross member I took a plasma cutter and cleareanced the left side, you can check that easy enough by power braking and seeing if the noise occurs. On a side note,when I had the steering shaft problem, when I would get on the gas hard the steering wheel would bind when trying to turn.
Old Jan 29, 2012 | 12:32 AM
theeddie's Avatar
was banging the tranny thx !
Old Jan 29, 2012 | 01:14 AM
pullejo's Avatar
'12 E63, E55(sold), C32 (sold), '65 Skylark GS 445 convertible, '12 ML350
You were what?!?! I'm not sure that's appropriate dialog for this board.
Old Jan 29, 2012 | 01:16 AM
theeddie's Avatar
wow how did i mis that lol
Old Jan 29, 2012 | 01:30 AM
pullejo's Avatar
I know.... That was a friggin' lob!!!
Old Jan 29, 2012 | 11:48 PM
Evolved8's Avatar
AMG Fam
where was it hitting on the tranny'?
Old Jan 30, 2012 | 12:18 AM
Denroll's Avatar
'06 E55
Probably in the rear... ... ...
Old Jan 30, 2012 | 07:31 AM
Tech-Tune's Avatar
2006 CLS55 & 2002 SL55 (R129) Silver Arrow
And the hits keep cuming... hilarious
Old Jan 30, 2012 | 12:56 PM
theeddie's Avatar
right at the drivers side at the x pipe
i would of taken pictures but forgot in the heat of the moment
