My clean block, new pulley, new headers and 850HP
PLATINUM SPONSOR
Here is one of my blocks that has been prepped and ready to go out to be machined for sleeves. The stock aluminum bores will be totally removed from the block ,, just like in this vid. at bottom of thread.
New 195mm, to go with the new lightweight/smaller SC pulley and idler pulleys. Total drive will be about 207mm when you add te 195mm to the new light , smaller SC pulley.
![](http://i991.photobucket.com/albums/af31/Vitabc/2012-01-27080035.jpg)
![](http://i991.photobucket.com/albums/af31/Vitabc/2012-01-27080142.jpg)
New custom headers,, Same as a few other members but no down pipe, so I can hang turbos, when the time comes. Still sizing turbos but real cloe now.
![](http://i991.photobucket.com/albums/af31/Vitabc/2012-01-25113955.jpg)
Check out the custom tig welded pyramid in the collector. I am not aware of any headers made for the 55 motor , than can flow as much as these headers. 1 7/8 primaries and the collector angle and size allows max flow of boosted gases. Just have to weld the large thck turbo flange on or maybe just a ball end flange ,, until turbos get worked out. Goal is to get back on road first...
![](http://i991.photobucket.com/albums/af31/Vitabc/2012-01-27082920.jpg)
http://www.youtube.com/watch?v=GU32Q6QXtWQ
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
i'm guessing your beast will go Ricky Bobby fast when all put back together?
you going to gut the car or make it the ULTIMATE SLEEPER?
2003 E55 & 2014 GL550
Gotta a feeling a super friendly Exotic/V12 God 1/4 mile showdown is in the works.
Winner is the one who hooks up the most in the 1/4. Be funny watching E55's peddling it down the 1/4.
We need to PPV that puppy!!!!
PLATINUM SPONSOR
Lot of funny replies. LOL I just want back on the road. Been 3 months now!!
That would be fun. Cars may weigh the same with his big V12.
__________________
www.ultimatepd.com
www.ultimatepd.com
1 7/8" primaries are probably not going to be the best for a turbo...especially if you are going to run twins, as you seem to suggest... just my .02
05 White Pano E55, Cadillac CTS-V
What kind of power are looking for anyway? I would definitely reconsider using those big primaries.
PLATINUM SPONSOR
With just a turbo engine, I would agree with your to large of header scenario but this is a unique twin charged set up, so remember my exhaust will be under boost /pressure. Turbos will only be doing part of the job on this set up. All I a saying, is this is a new set up for our AMG`s and some out of the box methods will be used.
My new sleeved block is coming along now. In the meantime, fitting a spare block and heads into my engine bay,so I can start to fabricate my turbo setup. Also will be putting a single turbo on GL450 in the near future and have some quick short cut ideas on this set up.
__________________
www.ultimatepd.com
www.ultimatepd.com
V12-Biturbo
Way to step up Brook! Love the out of the box thinking & enthusiasm
Nothing excites TRUE modaholics better... Embarking on NEW never been seen before Twin charged CL55 so kool... Wish you BEST OF LUCK!
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
What size are the factory head bolts, or are they studs? Your def gonna want some high quality studs and depending on the size look into having the block/heads machined to accept a bigger stud. 4 studs per cylinder plus big boost can lead to pushing water. Wondering if you've considered that aspect and what you've found?
