Correction programming in STAR DAS
Old Jan 31, 2012 | 05:24 PM
£ C43 £ AMG £'s Avatar
E55K AMG
Does anyone have any info regarding the IGNITION & FUEL QUANTITY correction programming and STAR DAS?
Both allow for three options
Ignition Octane (RON) = 89>, 91>, 93>
Fuel quantity = LEAN OUT, SLIGHTLY ENRICH, ENRICH
Currently I think the default option is using the base value. Cheers
Old Jan 31, 2012 | 09:07 PM
Shifter's Avatar
E55, SL63, ML550
I have played with it a little, If I remember correctly, I could only adjust for Ignition octane(in the U.S.) for the E55. (I bumped mine all the way up)
However I do know you could adjust for fuel quantity on other motors like the 111k.
Old Feb 1, 2012 | 08:27 AM
E55K AMG
In the uk we have 95, 97 and 99 RON so was not sure how the correction programming translates.
Also for fuel quantity I cant imgaine that you would want to LEAN OUT unless you live in a very cold climate all the time.
thanks
Old Feb 1, 2012 | 08:33 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
I think if you select the base valve it learns the fuel quality.
Old Feb 1, 2012 | 01:49 PM
xpl0sive's Avatar
CLS55 AMG
is there a way to reset the fuel quality? my car is originally from Florida where the best gas they have is 91 or 92 octane i think. Here we have 94 octane avaliable, i feel that my car is used to the 91 octane. where in DAS do i find the settings of octane?
Old Feb 1, 2012 | 10:58 PM
Shifter's Avatar
E55, SL63, ML550
ME-adaptations-correction programming-
Old Feb 2, 2012 | 08:19 AM
E55K AMG
Ok thanks, sounds like the safest option to select. especially if the 99 RON option is not listed .......which it is not.
