How many here running 180 pulley without fuel rail or inejctors?
...personally, if I didn't need my license to work I'd get the injectors and fuel rail even with the small pulley because God knows I'd be doing my Scottie impression as often as I could "I'm giving her all she's got Captain".....
The majority of the people on here who are modded up all have basically the same mods but power numbers from dyno graphs shown range a good 60-80whp. Now of course different dynos are going to show different numbers, but also how the car was tuned can affect things quite a bit. So don't look at just a magical "180 pulley" being a make or break item of if your car will last or not. Sure the bigger the pulley the more heat it is going to bring which doesn't help any cause though.
The proof is in the numbers:
For those who don't know how to calculate injector duty cycle. At 5639rpm the duty cycle is at 102%. At 6503rpm it's at 126%. 100% is static so anything over that is static as well.
BTW- who was the member that blew his engine with fuel upgrades?
keksigma (Kaylan)
He had 15% compression loss in #8 BEFORE ever adding the looped fuel rail.... the damage had already been done from previous WOT pulls through 3rd and into 4th gear. The results of the compression test seem to be the forgotten part of that story...
The time to add the fuel upgrades is before you think you need it, not after.
-G
