Car nosedives on 2-3 shift
Old Feb 21, 2012 | 11:53 AM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
Originally Posted by adianaty
Just to be clear with my experience, I never had a problem prior to the TCU tune so I'm not sure we can rule it out. It is likely that the ECU is taking control of it but prior to the TCU tune I had no issues and it is not happening in all E55's either since there are 2 other cars local to me with similar mods that do not do it.
mine does it without TCU tune so therefor it cannot be a TCU tune causing it on my car since i do not have a TCU tune
Old Feb 21, 2012 | 12:06 PM
xtyper's Avatar
2013 E63 AMG
Guys, I really don't think it has anything to do with your TCU tune since my 2011 C63 does the same thing and my TCU hasn't been touched (nor can it for that matter since I think it's housed inside the tranny itself).
See my thread over on the C63 forum:
https://mbworld.org/forums/c63-amg-w...rag-strip.html
Old Feb 21, 2012 | 12:09 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
We see your thread bro.. Its been linked like 3 times now..
Old Feb 21, 2012 | 12:13 PM
adianaty's Avatar
E55, CTS-V Wagon, Duc 1098R
Maybe I wasn't being clear. All I said was not to rule it out and I agree that the ECU is likely controlling. In my case, once I did the TCU it happened. That's all I'm saying.
cij911's Avatar
one car at a time
it is not from the TCU tune- it happens on all e55s... mine does it and i have no TCU tune as well as other members without TCU tunes reporting the same thing
I am sorry but this problem does not happen on "all e55s" - stock and other modded cars have been free of this. I wonder if it is a heat issue.
Old Feb 21, 2012 | 12:20 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
if you read through the threads its happening to C63s and e55s. Some with our tune, some with our tune and tcu tune, some with oe tunes, some with renntech tunes.
We are on top of it and will figure out a solution.....
Old Feb 21, 2012 | 12:24 PM
  #32
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
My car doesnot do this.
Old Feb 21, 2012 | 12:26 PM
  #33
loungn14's Avatar
SPONSOR
neither does mine, but I am starting to wonder if its a trans thing or worn clutch packs...
Old Feb 21, 2012 | 12:31 PM
  #34
whipplem104's Avatar
1990 300ce supercharged and intercooled
Besides tunes there is also the distinct possibility that you guys are just slipping in the the transmission and that the computers are pulling power more from that. If you have a lot of power and the shift does not complete in the correct amount of time then the car will extend shift time and pull back more. The more power you make the more it will be noticeable. Might be time for a trans build or at least modified valve bodies.
Old Feb 21, 2012 | 12:37 PM
  #35
xtyper's Avatar
2013 E63 AMG
Damn, tough crowd over here.
Old Feb 21, 2012 | 12:50 PM
  #36
skratch77's Avatar
2005 E55
lol but you needto understand that we dont share a single thing with you c63 guys.
your issue can be something completely different.
We have an ancient tranny that was built from aliens and need to get this sorted out.
We only wish we had the 7 speed in our cars
Old Feb 21, 2012 | 01:11 PM
  #37
Evolved8's Avatar
AMG Fam
I don't think its slipping, It just feels like the car electronically does something to stop either fuel delivery, close throttle body etc for that split .5 second. It literally feels like a glitch of some sort.
Old Feb 21, 2012 | 01:12 PM
  #38
Roverron's Avatar
ML63
Hey I said that I didn't notice this until my TCU tune I am not point fingers or suggesting anything. I also said I don't go full throttle much. With the TCU tune I might have pushed my car more than usual to see how well it shifted that is when I noticed the stalling or whatever you want to call it.
Damn I was hoping I could blame it on the TCU for a free fix by "Team Euro Charge".
Old Feb 21, 2012 | 01:22 PM
  #39
grantwoodtx's Avatar
GLE 63S
Mine does it even when the car is not heat soaked.
Old Feb 21, 2012 | 01:37 PM
  #40
GT-ER's Avatar
2005 E55 AMG
Mine does it 100% of the time even with the engine cool and I don't have a tcu reflash.
Old Feb 21, 2012 | 01:39 PM
  #41
e55amgrocket's Avatar
Dirt Scooters
It's not slipping at all. I have a diesel truck with the stock trans back in that makes 1200+ft/lbs of torque and I know what slipping is. This is a computer related problem and the extra power just makes it happen a lot worse. Just another hurdle to get over that's all.
Old Feb 21, 2012 | 01:40 PM
  #42
skratch77's Avatar
2005 E55
Can you make a video gtr?
Old Feb 21, 2012 | 01:43 PM
  #43
BlkE55K's Avatar
2010 E350, 2011 ML350, 2003 996TT
Well if the EC guys can figure this out through a TCU update, that may benefit others who don't yet have the TCU tune.
Old Feb 21, 2012 | 03:07 PM
  #44
You are miss understanding me. If the computer detects during a shift that it cannot complete the shift in the set times. It will pull back more on the engine. Also if you are making a lot more power than stock it will pull back more for shifts. You might be able to tune it out by increasing the shift pressures to complete the shifts faster or in combination of reducing the torque reduction during shifts. You do not want to remove all the torque reduction though as this will seriously require a built transmission. I build and tune these transmissions all the time and the shifting is very complicated. Without tq reduction things need to be very precise on the clearances and pressures. It is a clutch to clutch transmission and it makes the shifts very difficult. Stock clearances almost require a fair amount of tq reduction to prevent a flair up in the shift. Especially the 3-4 shift. But regardless if you are pushing full throttle and the shift cannot be completed in time it will either hit the rev limiter or at least pull back on the motor pretty severely.
Old Feb 21, 2012 | 03:11 PM
  #45
Dirt Scooters
I see what your saying now. It seemed like it would do better some runs than others and without full throttle it was alot better. It might have something to do with the transmission still adapting too. Hopefully we can get this figured out soon.
Old Feb 21, 2012 | 03:28 PM
  #46
skratch77's Avatar
2005 E55
Did you reset adaptation before the event? I had the same exact issues when I did the sneaky reset at the track.
I got the car at one point to hit the rev limiter in D going to the 2-3 shift and the next lap the car waited like .5 second to shift to 3rd.
I have not done a reset since then and I think its you car adapting and freaking out going down the track.
if the shift is to slow it will hit the rev limitor and didnt Jerry say they increased the shift point? maybe the ecu is hitting a limiter since the tcu is alowing the car to rev higher?
Old Feb 21, 2012 | 04:16 PM
  #47
adianaty's Avatar
This is very helpful and makes sense. When I did my TCU they also changed the torque limiters in the ECU so this fits.
Old Feb 21, 2012 | 04:47 PM
  #48
Helli217's Avatar
05 E55
My car does seem to reduced power in the split seconds surrounding a shift, but has never fallen on it's face or hit the rev limiter--niether when it was stock, nor with upgraded cooling, and EC ECU/TCU tunes. I am still on stock pulley. Interested to see if the warmer weather will affect it.
Old Feb 21, 2012 | 04:55 PM
  #49
GT-ER's Avatar
2005 E55 AMG
I just got another reflash from Jerry and it feel MUUCCHHH better. It'll still do a tiny split second hesitation but it's no-where near as bad as it was before. While the hesitation was never LONG persay, it was very noticeable as if my car would lose 200whp for .5 seconds. Now it feels like loses maybe 40whp for .25 seconds. It's stupid quick now.
I'll be honest though, I think I don't want the shift any stronger ( bang, skreetch for example ) because we have to worry about our drivetrains and stressing the parts just to have a super strong shift is not really gonna make us much faster and will brake parts a lot quicker. I think that with quicker shifts ( such as those from EC's TCU ) and the amount of torque management my car has right now ( after the re-tune ) is perfect.
Old Feb 21, 2012 | 05:39 PM
  #50
AKnight55's Avatar
What ended up being the adjustment made?
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
