Cluster Swap W/Mileage Retained-No SDS
Old Feb 24, 2021 | 07:55 PM
mira's Avatar
e320
I am new member. can't PM. please email me instructions how to "virginize" used cluster. have xentry. thanks.
vjeko57 at hotmail
Old Feb 24, 2021 | 07:56 PM
mira's Avatar
e320
Originally Posted by Mackhack
If you need to have a used cluster virginized to be able to marry it with your own car for a cluster swap contact me via PM.
If the used new cluster has less miles than your current cluster DO NOT connect the cluster until the cluster is virgin again.
If you ignore this, your EIS will take over the lower miles and cause chaos. It is also illegal to lower your mileage.
vjeko57 at hotmail
Old Feb 4, 2023 | 11:37 AM
igorj's Avatar
2007 w211 220CDI
Please send to me, i have the same situation.
Thanks in advance.
Regards
Old Feb 4, 2023 | 06:31 PM
Wli's Avatar
Wli
W124 E280T , W211 E240
Thanks in advance.
Regards
what do you need? How to swap or how to use program it?
Old Feb 6, 2023 | 04:45 AM
igorj's Avatar
2007 w211 220CDI
I have swaped instrument cluster A2115406048 in my car (2007 E-Class 220CDI 170HP), with instrument cluster A2115400347 from older model. Info regarding km is synchronized, but some features are not (runflat indicator, gps, tank size and so on). Also, reports malfunction about non-existent device.
I still have the old cluster, but is doesn't turn on. So. how i can solved this? What can i do and how? Is it posible to do a software upgrade with newest version which support my car model?
Thanks in advance.
Regards
Old Oct 4, 2023 | 11:35 PM
Edgar Torres's Avatar
2007 s550
Does this also work with w221 model? I’m also in the same boat.
Old Dec 23, 2023 | 12:57 AM
  #32
Mr_Erbach's Avatar
CLK W209
Just for let you guys know this post saved my life! lol...
I did retrofit the cluster of my CLK 350 W209 from the standard black to the silver with white gauges then the odometer showed ------ so I did swap the "brains" like Nealgobert said and voila! We are back again with OEM mileage and features. No soldering No complications just swap the circuits. (the one with the connector)
Thank you so much!
Old Jan 31, 2024 | 09:47 AM
  #33
Crawdady's Avatar
Mercedes-Benz 2005 E500 4matic
Thank you so much!
I have a 2005 E500 4matic all the fuses are good I do have an mb2 for my car so I have the correct scanner it tells me that my cluster is dead so I can switch the brain out from the new one I got and put it in the old body and it should work correct
Old Jan 31, 2024 | 09:48 AM
  #34
Crawdady's Avatar
Instrument cluster on w211 2005 E500 4matic
Thank you so much!
I have a 2005 E500 4matic all the fuses are good I do have an mb2 for my car so I have the correct scanner. it tells me that my cluster is dead so I can switch the brain out out of my old instrument panel and put it in my new one and it should work correct? I would appreciate any help I could get thank you the reason why I asked is because.it doesn't seem like the brain itself would go bad it would be the part where it plugs in or some other electrical components that provide the electrical current went bad most likely but I could not picture the brain going bad the odds of that happening versus the other are probably slim.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
