2003 E55 AMG Dyno Results
Old Feb 29, 2012 | 04:34 PM
vioilio's Avatar
2003 E55 AMG
Originally Posted by skratch77
you can buy an obd2 scanner that can show live data and use that to look at your intake air temps.
Once you tell us those temps we can rule out if your supercharger pump is dead or not.
Having a basic scan tool that can do some live data is a must for cars like ours.
Thank you so much for this information. I will report back tomorrow with some real intake temperature numbers.
Old Mar 1, 2012 | 09:59 AM
vioilio's Avatar
2003 E55 AMG
Car is maintaining 120F-128F Intake Air temperatures on normal drive to work. 70MPH on I-95 outside temperature was 48F. Is this normal?
Old Mar 1, 2012 | 10:02 AM
e55amgrocket's Avatar
Dirt Scooters
Get a new intercooler pump. If your IAT's are that high at cruise when it's that cold its bad.
Old Mar 1, 2012 | 10:09 AM
grantwoodtx's Avatar
GLE 63S
^^^^^^ What he said.
With an ambient of 75 last weeknd mine didn't get above 128F during 3-4 bursts of heavy acceleration and fall back to 90-95F very quickly.
I have an EC larger HE and CM30 pump. I also don't have my circuit split.
skratch77's Avatar
2005 E55
You have a dead pump
vioilio's Avatar
2003 E55 AMG
I already ordered the Johnson CM30 Pump. The car does have the Evosport Cooling Package. This never came with an upgraded intercooler pump correct? It is just an upgraded main water pump that is included?!
Do you think that the Intr. Pump might be the culprit?
Old Mar 1, 2012 | 10:22 AM
  #32
vioilio's Avatar
2003 E55 AMG
For all of you that need a new Intrc. Pump the cheapest I found was:
http://autoperformanceengineering.com/html/jabsco.html
The price is $145 shipped.
Use coupon code: starquest
Your total would be $123.25
This is awesome deal.
Hopefully this will fix my problem.
Old Mar 1, 2012 | 10:39 AM
  #33
GLE 63S
If it has the Evosport cooling package, the pump supplied replaces the stock Bosch HE pump. You'll need to contact Evosport for a replacement pump I believe.
