Help!! Car dies hard to start and or doesn't?
2005 e55
I have an 05 e55 and it all started with the car dying on the hwy last year only to restart. It happened a few times and so I replaced the crank sensor and thought all was well. I was driving yesterday and the car died again but the difference was this time the car misfired before dying and threw codes p0300, p0303, and p0305. I know these are misfire codes and just wondered if anyone has had this happen as I don't want to keep throwing parts at it although my assumption now is cam sensor?? Any thoughts would be appreciated.
It could be cam position sensor. Checked plug wire and plugs recently? Coilpacks OK?
Try an ECU reset and then reset your codes. Drive the car and see if the missfire comes back.
1 Post
07 E63 AMG / 07 C230 / 14 E350
Here are the causes..
Symptoms
Symptoms may include:
A code P0303 may mean that one or more of the following has happened:
Symptoms
- the engine may be harder to start
- the engine may stumble / stumble, and/or hesitate
- other symptoms may also be present
- Faulty spark plug or wire
- Faulty coil (pack)
- Faulty oxygen sensor(s)
- Faulty fuel injector
- Burned exhaust valve
- Faulty catalytic converter(s)
- Running out of fuel
- Poor compression
- Defective computer
2005 e55
Thanks, the car when it died stumbled alittle and stopped but when you go to restart the car, the car turns over with not a hint of spark and after sitting awhile it will start up like nothing was wrong?? Having it miss firing on more than one cylinder I was thinking cam sensor but don't know and this has a kleemann tune and pulleys and exhaust with 50k miles.
