Thanks Jeremy and Bruce
![Thumbs up](https://mbworld.org/forums/images/icons/icon14.gif)
Despite a record high today of 85F, I had the beast re-tuned and dyno tested.
The beast pulls like a ****ing freight train, and once Bruce gets a chance to work more of his magic it will be even stronger. I'm very pleased with the results thus far. As can be seen by the fueling graph, there is still power left on the table and a nice cushion for when the temps drop.
Tests were done on a Mustang load bearing dyno.
![](http://img812.imageshack.us/img812/7714/finalgraph.png)
Thanks! I can't wait to get it out to the track on a 50F day and see what the numbers really mean. Though it is nice to quantify gains from mod to mod etc.
Headers, pulley, fueling kit, HE, trunk tank etc. Have quite a few other ideas yet, but so far the car feels good.
It's interesting to note that towards the end of the pulls, and every log I've done, shows that as the car gets closer to redline the TB begins to slowly close. TPS goes from 98-99% down to about 90% at redline. TPS shows that, regardless of what gear the car is in, the TB starts closing at about 5800RPM.
Also, with the fuel here having 10% ethanol, AFR numbers are quite a bit different than I originally thought. I believe that stoich with 10% ethanol is 14.2 instead of 14.68. Knowing this I think that AFR numbers that people see with datalogging equipment may actually be quite a bit off; does anyone have any further insight on this? Am I way off base?
Found this for anyone interested: http://ls1tuningguide.com/files/free...conversion.pdf
Despite the mass exodus hopefully someone finds it useful; I know I do.
WOW, that is an impressive graph, nice flat tq curve and power keeps pulling, even up top. Shweet HP under the curve too homey, and are you on the stock t/b?
185 ASP welded design.
Of interest, after Jeremy solidified the file, (which only took one revision), I made a final pass with the trunk tank full of ice. While it kept the IAT's in check, I must not have had any issues with IAT's. The AFR, timing, and HP/TQ numbers all stayed the same.
