NEED HELP ANY IDEAS!!!!! Engine Missing
Old Mar 23, 2012 | 07:51 PM
BRABUS786's Avatar
Stage 3 63
Hey
Guys
as most of you know im building my E55 Wagon,
The engine has had a full Rebuild, 200mm pulley race heads Kleemann cams 82tb EC injectors etc......
The problem I am have is that the engine decides to miss and starts hunting turn the car on and off it goes fine but as soon as i put my foot down its starts to hunt again!
The car has been mapped by jerry but will be fine-tuned next week!
The following things i have done! Can anyone help out!
Checked all injectors are pulsing
Replaced the EC injectors with Stock injectors
Tested cylinders for compression all fine
Checked all brand new plugs
Changed all coil packs and leads
Removed the SC and re sealed everything
Checked 82mm TB with stock TB
Checked all breather pipes for leaks
Opened the ECu and cleaned it
checked the wiring from the ECU.
But still i have the same problem
Have a look at this short video of how the TB is acting with the engine starts to miss fire
http://www.youtube.com/watch?v=-5EWs...ature=youtu.be
Acid
Old Mar 23, 2012 | 08:11 PM
02S430's Avatar
W220 M113K
I know you said you checked, but did you change the plugs and wires? are they in the correct spots?
Old Mar 23, 2012 | 08:26 PM
BRABUS786's Avatar
Stage 3 63
yep : ) and changed coils!
Old Mar 23, 2012 | 08:52 PM
blackbenzz's Avatar
haters crazy
Any codes? You have your map sensor connected?
Old Mar 23, 2012 | 08:55 PM
vioilio's Avatar
2003 E55 AMG
valves???? did the engine ran fine after the rebuild and race heads?
Old Mar 23, 2012 | 09:27 PM
BRABUS786's Avatar
Stage 3 63
Everything in the heads are new and so are the valves, I have only done 500km side the rebuild the engines not been running fine since I started it but the problem comes and go and it's really pissing me off !
BRABUS786's Avatar
Stage 3 63
No codes no errors
Old Mar 23, 2012 | 09:46 PM
e55amgrocket's Avatar
Dirt Scooters
I had that problem before. I would turn the car off and restart it and it would be fine. Changed plugs,wires,crank sensor and no help. All of a sudden it went away.
Old Mar 23, 2012 | 09:57 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
I have seen that with clogged cats before, but don't you run open exhaust?
Old Mar 23, 2012 | 11:04 PM
KLR CLS's Avatar
CLS63 PP
Engine missing? Have you checked under the bonnet?
(soory, had too..)
