Having 18 inch stock wheel . faster acceleration than 19" , 20"
Just wondering if having a smaller wheel , will help to accelerate faster
than having 19 or 20" wheel . I mean if you are car does 700rwhp , I think
it wont really matter but, what is good for having a smaller wheel ?
I know that it gives you a better fuel economy , and buying tires are
cheaper since its smaller size .
Thank you and any input is appreciated.
Since the force, momentum… are all proportionate to the square of the radius, the amount of force required to accelerate your wheel assembly goes up exponentially as it’s radius of gyration increases.
Also, a smaller than stock rolling diameter of the driven wheels has the same effect as lowering the gearing of the car, which improves acceleration.
2 wheels of the same weight with one having 70% of the weight close to the hub will accelerate quicker than a wheel weighing the same except with 70% of its weight at the outer edge of the wheel...
simple physics
the further the weight of the wheel is from the hub, the more amplified that weight is.... take a 5lb weight and put it on a metal rod and hold it out in front of you with the weight 1 ft from you on the rod and then slide it 5 ft further away on the rod and see how much heavier it becomes..
same concept when going to larger wheels... you car has to do extra work to start the rotation of mass that is further away from the hub
simple physics
and i am still also looking for an answer for a noise coming from my dash that i posted in another thread with video and i would love a long or short answer, as i am stumped
I think with forged rim ~ Car will power slide all over the place !!
As mentioned earlier it is about the rotational weight of the rim (assuming you keep the overall diameter more / less the same)....Most judge the rotational weight by the static weight and the stock rims are pretty heavy. If you bought a great rim (e.g. HRE) in an 18 or 19" and dropped your rotational mass by ~5lbs per rim, you should see an improvement. Now if you go bigger and wider and your rim and tire combo weigh more, then you will be slower in straight line performance.
Maybe the stock E63 wheel would be ok, but the chrome process I'm sure adds a lot of dumb weight you don't necessarily need. And because the other three are chrome I would have to buy all 4 new rims at $1080x4!!
Also, my tires weigh a little more now that I stuck 285/35's in the Rear. So it is right under the same weight as a normal E63 wheel without chroming and 265's. I also get the extra traction to not "power slide all over the place!"
blinky blinky all the time lol
blink until 60 -70MPH !
I do have some problems with my ELM v2, and I can't really make it go any lower otherwise I will start burning off the corner of the tire with my rear fender. So the car is a bit angled toward the front lower and the rear at or near stock height.
The big difference in traction wasn't too crazy, but it did help me get away from the horrible 265 tire sizes we are offered that are way overpriced, like the Michelin PS2's on my stock wheels, those are horrible at launches, but very good in the twisties.
I ended up going with Toyo T1R's for a bit, until one blew on me around 12k in. Now i'm sitting on the Hankook Ventus RS3's and they aren't bad $$$ wise. I think the toyo's hook a bit better. But overall those 20mm's will and should help you get off the line without spinning them as hard as any 265 tire as there isn't many to choose from.
I'm going to slap on some Nitto NT-05's all around for my next tire. I just think the PS2's are overpriced and everyone gives them high praise! I only got 8k out of my rears on the PS2's and it's no fun to replace $300/ea tire.
dont forget its not rim height but total overall height that matters
ock 18s
