WOT hesitation after EC tune
Old Mar 31, 2012 | 11:05 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
did ya properly purge the system after pump install?
Old Mar 31, 2012 | 11:09 PM
BenJ's Avatar
2003 E55 AMG
The he pump? Not sure. I know the shop had to add some coolant to it or whatever fluid is used. Could this be the issue? Its a shuddering feeling as the car goes WOT.
Old Mar 31, 2012 | 11:12 PM
BenJ's Avatar
2003 E55 AMG
No cels as of yet either. If the iat's were high, wouldn't the supercharger just not engage and the car wouldn't hesitate?
Old Apr 1, 2012 | 12:22 AM
cij911's Avatar
one car at a time
Originally Posted by BenJ
I tried to purchase a live scanning tool today that has playback but they were sold out so I'm going to have to wait until Monday and run the car by benzworks in huntington beach for them to diagnose. I also got word back from adam at EC and he recommended a re-flash so depending what we find on Monday, I will reflash possibly. Hoping it is something simple like the belt slipping
Benj - I am in OC if you want you can borrow my Innovate OT2 and check codes and see your IAT (at least rule out the pump). I have read several posts of CM30s going bad very quickly or being DOA.
Old Apr 1, 2012 | 12:42 AM
jayjmuir's Avatar
2007 E63 AMG (Dubai), 2009 BMW X5 4.8i Sport (PA)
I'm about to purchase one as well. Are the cheap $20 Bluetooth units ok or should I go with the $80 Kiwi unit?
Old Apr 1, 2012 | 01:33 AM
BenJ's Avatar
2003 E55 AMG
I might take you up on that, thanks. Yeah, I've heard that too. I would be fairly pissed if that's the case, but would high iat's cause my symptoms, or would the supercharger just not engage and I would be low on power? The hesitation feels like timing is being pulled more than anything else.
Old Apr 1, 2012 | 02:24 AM
  #32
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
This issue is common on stage 3+ cars when going full wot on the streets from 3rd to 4th in s mode
Only fix I have seen so far to go wot with out the hesitation is to use M mode
IF you do find a fix do let me know
from what i recall it was something related to torq limiters, but that was just a statement
Old Apr 1, 2012 | 12:32 PM
  #33
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Try "dyno mode" and see if that clears it. Quite frankly, I have not experienced this problem and I consider my E55 to be pretty stout.
Old Apr 1, 2012 | 12:51 PM
  #34
BenJ's Avatar
2003 E55 AMG
The issue remains in all 3 modes; C, S, and M.
Old Apr 1, 2012 | 08:43 PM
  #35
BenJ's Avatar
2003 E55 AMG
Well, I don't want to say for sure quite yet, but the problem seems to have solved itself. I'm going to go out a little later and try a 4th gear pull to be sure, but 2nd and 3rd felt great with no issues a few minutes ago.
Old Apr 2, 2012 | 09:26 AM
  #36
moosejaw's Avatar
none
As jake said above did you purge the system after the pump install?
Old Apr 2, 2012 | 09:47 AM
  #37
James@ACG's Avatar
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
Yes it was, Ben let us know if you have any questions or need ny assistance.
James@ACG
