WOT hesitation after EC tune
Old Mar 31, 2012 | 01:15 AM
BenJ's Avatar
2003 E55 AMG
I just received a EC tune for my e55 a few days ago...only mods being the EC 172mm pulley. At wot it feels good in first gear but in the top of second gear and all of 3,4, and 5th it feels like esp is kicking in where the power will fall off then kick in then fall off in a rythmic fashion if that makes sense.
I thought that it might be the fuel pumps not getting enough fuel to the injectors as they had about 60k on them. I replaced both and same issue. I also have brand new spark plugs.
What could the issue be? Any ideas that you can give me without taking the car on a dyno to diagnose? I'm going to swing by an auto shop tomorrow morning and see if there are any codes. The cel is not on, is it possible that there is a code being thrown and this can be causing the issue, even though the cel is off?
The car drove perfectly fine prior to the tune with no wot issues and this current hesitation issue only happens at wot. If I go half to 3/4 throttle it is fine.
Any insight would be helpful.
Old Mar 31, 2012 | 03:15 AM
jayjmuir's Avatar
2007 E63 AMG (Dubai), 2009 BMW X5 4.8i Sport (PA)
I'm having this exact same issue on my E63. I just got tuned a couple weeks ago. I haven't had a chance yet to investigate, since the car runs perfectly fine most of the time, but I'll probably dig into things on Tuesday. I was thinking fuel pumps too but I'll look at some other things since that didn't fix your problem. If my shop can't find anything, I'll give Jerry a call and see if he has run into this issue before.
Keep us posted if you find anything and I'll do the same.
Old Mar 31, 2012 | 03:23 AM
tbal's Avatar
Haters crazy
Try unplugging the battery overnight... resets all adaptions.
Old Mar 31, 2012 | 03:25 AM
kustom2k1's Avatar
03SL55
I have an OEtune and experience the same issue but, It happens when temps get too high.... If I make 2 consecutive passes down the track. If you dont have a HE, get one and check your IC pump..Contact EC.
Old Mar 31, 2012 | 07:28 AM
Turbotalon92's Avatar
E55
Warmer weather, heat soak, makes sense to me. Could be pulling timing, not sure about these cars, but assume they have knock sensors. Contacting EC is the best bet, they are the pros.
Old Mar 31, 2012 | 07:31 AM
jayjmuir's Avatar
What about for an E63 with the same symptoms?
Old Mar 31, 2012 | 10:10 AM
AWOL's Avatar
e55
Video?
Old Mar 31, 2012 | 10:54 AM
BenJ's Avatar
2003 E55 AMG
I will make a video and I just replaced the HE pump with a new johnson cm30 from EC as well. I contacted adam over at EC yesterday and I'm waiting to hear back.
Old Mar 31, 2012 | 10:59 AM
BenJ's Avatar
2003 E55 AMG
I'm running the stock HE as well, but the ambient temps were around 65F the past couple days and I wasn't driving the car hard at all.
Old Mar 31, 2012 | 11:06 AM
BenJ's Avatar
2003 E55 AMG
From what I've experienced so far, the hesitation will occur irregardless of the car being cool or not. I've ruled out the injectors for now as well given the cars flawless performance prior to the tune. I'm almost thinking that maybe I got a tune for a 175 pulley and not the 172 or something along those lines as the hesitation does feel like timing is being retarded, just not sure....is that even possible? I will try the battery unplug tonight as well.
Old Mar 31, 2012 | 11:29 AM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
Have you contacted EC?
Old Mar 31, 2012 | 11:35 AM
BenJ's Avatar
2003 E55 AMG
Yeah
Old Mar 31, 2012 | 11:44 AM
kustom2k1's Avatar
03SL55
Best thing both of you can do is speak to EC and maybe get a re-flash.
TheVazha's Avatar
W213 E63
Any other unusual noise when the power "falls off and kicks in"?
Old Mar 31, 2012 | 11:52 AM
BenJ's Avatar
2003 E55 AMG
No, just that it happens fast...as in a fast pulsing in the power; on off on off on off.
Old Mar 31, 2012 | 11:57 AM
BenJ's Avatar
2003 E55 AMG
Also no unusual sounds or leaks.
Old Mar 31, 2012 | 12:42 PM
cij911's Avatar
one car at a time
Log your car and you will likely have your answer....Who installed your pulley ? ( I have a 175mm and add on pieces that I need to have installed...)
Old Mar 31, 2012 | 12:50 PM
BenJ's Avatar
2003 E55 AMG
I used a mbworld vendor, ACG in san diego.
Old Mar 31, 2012 | 01:49 PM
outrun's Avatar
2004 E55
And GermanMemberAMG OUT OF NO WHERE WITH IMPORTANT INFO!
Old Mar 31, 2012 | 02:08 PM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
I have a home in Germany too. Please post the Mercedes/AMG part numbers.
Thank you
Old Mar 31, 2012 | 04:52 PM
TheVazha's Avatar
W213 E63
Maybe tranny slip? Belt slip?
Old Mar 31, 2012 | 06:41 PM
BenJ's Avatar
2003 E55 AMG
Not sure how the tranny could be slipping that bad and at that power level...maybe belt slipping...
Old Mar 31, 2012 | 06:52 PM
cij911's Avatar
one car at a time
Since we are all guessing....I am going to guess in order of likelihood :
(1) Your IATs are climbing b/c the CM30 is not working...and the S/C is cutting out
(2) Your car is running too lean, knocking, and the ECU is pulling a ton of timing...
(3) Belt slippage if the issue is RPM based irregardless of gear
Old Mar 31, 2012 | 08:20 PM
BenJ's Avatar
2003 E55 AMG
Yeah, all guesses at this point. I would initially rule out the pump as its brand new and it has been pretty cold the past couple days and the hesitation occurs all the time, even if I were to start the car for a minute then go wot. Number 2 sounds right, at least that is my guess currently and the belt slipping is also a possibility as this only happens at wot when the supercharger is engaged.
Old Mar 31, 2012 | 08:23 PM
BenJ's Avatar
2003 E55 AMG
I tried to purchase a live scanning tool today that has playback but they were sold out so I'm going to have to wait until Monday and run the car by benzworks in huntington beach for them to diagnose. I also got word back from adam at EC and he recommended a re-flash so depending what we find on Monday, I will reflash possibly. Hoping it is something simple like the belt slipping
