Ultimate E55 Engine
Old Apr 2, 2012 | 08:01 AM
e500slr's Avatar
2011 E63, 2013 CLS63
Ultimate E55 Engine
Let's say money was no object and you can even include custom work, what mods and work would you do to a 55 engine and gearbox. Let's leave turbocharging and stuff out, let's talk more realistic mods that can be done. What would be your ultimate 55 engine and gearbox. List mods...GO!
Engine
  • (empty)
  • (empty)
  • (empty)
Gearbox
  • (empty)
  • (empty)
  • (empty)
Old Apr 2, 2012 | 08:27 AM
e55amgrocket's Avatar
Dirt Scooters
Remove it and put a LSX in.
Old Apr 2, 2012 | 08:47 AM
GregMB's Avatar
"Money no object" build implies that there's no need to be realistic.....
To me that implies either complete engine swaps or complex turbo setups.
-G
Old Apr 2, 2012 | 08:49 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
See SLR parts catalague ... honestly thats the bananas all round...
Outside of that its only limited to your budget.
for example ~15k€ will get you MKB top coolers
8k$ carbon ceramic brakes for weight...
I think you need to give budget parameters...
Old Apr 2, 2012 | 08:53 AM
GT-ER's Avatar
2005 E55 AMG
Why leave turbocharging out? It is absolutely a realistic thing to do and would definitely be #1 on my list if I had the cash. I would just slap SLR pistons and rods and add ported heads on an otherwise stock 55K and then install two GTX3582R turbochargers and watch my oem tranny/prop shaft explode when 900+wtrq shred it. Then just upgrade those units and see my E55 do 8's.
Old Apr 2, 2012 | 09:05 AM
AMGPilot's Avatar
2004 E55
Sorry guys I'm going to go with the LSX also
Old Apr 2, 2012 | 10:28 AM
Forrest Gump 9's Avatar
shrimp boat
Why limit yourself? He did say "money was no object". I'm going with a jet engine from a Cobra gunship.
Old Apr 2, 2012 | 10:30 AM
stevebez's Avatar
Or sell, get a 2012 E63 and run 10's with a tune...
Old Apr 2, 2012 | 10:32 AM
e500slr's Avatar
Well we are speaking hypothetically and a swap would be too drastic and too much modification. I'm talking about everyone's personal parts wish list.
You're right it would but since no one has done it yet its not really a straight up mod since custom fab needs to be done and testing and things could go wrong. By the way I didn't realize how expensive Ti rods were it's incredible.
Subtle but that's too realistic, I was talking about something insane and out of this world like....a heat exchanger
Old Apr 2, 2012 | 10:37 AM
e500slr's Avatar
You have alot of mods already....and the fastest 55 so your list of mods is gonna be one of the shortest but that does make you top dog in the 55 clan
Old Apr 2, 2012 | 10:47 AM
stevebez's Avatar
OK Ill give it a go ...
Rear Tank with Johnson CM90, and a chiller package to keep water tank cool.
Front rad - not so sure all the stuff we are sold is taht much better then OEM so I would leave that be to start.
TB .. 82mm Rentech + their airbox and filters.
Pulley ... hmmm 180 ASP ... it works doesnt it?
Exhaust ... supersprint full long tubes... + eisenman back boxes, no cats.
Flowed heads
Forged pistons, and lighter rods while u at it.
Top mount SLR Coolers modified to fit our engine bay - with these will need to increase the front rad capacity though...
Gearbox spec to SL65 clutches, delimit the load limiter, increase shift speeds.
Lightweight wheels and carbon ceramic brakes...
Tune .. goodness knows but something custom...
What have I missed on purpose ?
Old Apr 2, 2012 | 11:00 AM
Dirt Scooters
LSX is the best/cheapest platform to make big power. You can take a stock LQ9 (6.0l truck engine),change the cam to a turbo cam and put a single or twins on it,new injectors and make 800 SAFE rwhp and turn it up to over 1000hp for fun. Parts are cheap,everything you can think of is available,anyone can tune them,tons of transmission choices, and blocks are a dime a dozen. Cant get much better than that. I had a LS2 GTO with a 440 LSX and had to be one of the funnest cars ive ever had. Torque everywhere,lots of power up top,spin to 7200rpm all day long and a 200 wet kit for fun. ***GTO T56's do not like powershifting*** 03-04 cobra's seemed to hold up better
Old Apr 2, 2012 | 11:06 AM
KLR CLS's Avatar
CLS63 PP
Flowed heads
Custom High lift Cams ground for low overlap( Blower cam specs)
Active cooling on SC Loop ( Killer chiller style)
90-100mm TB of some sort
2800 RPM Stall 11" Torque converter + beefed axles and 1 peice Driveshaft.
Also 3.06-3.55 gearing
Old Apr 2, 2012 | 11:46 AM
stevebez's Avatar
hmm might make a nice drag car .. but it will change the character too much wouldnt it?
Old Apr 2, 2012 | 01:59 PM
KLR CLS's Avatar
CLS63 PP
Big Cams, Gear and a High stall TC would COMPLETELY change the character of the car! For the good if you ask me ;-)>
Old Apr 2, 2012 | 02:25 PM
e500slr's Avatar
No doubt the LSX blocks are amazing and they're cheap that makes them even better. The M113 is no competition when it comes to value for money you're right but it's a pretty drastic mode to do an engine swap. Would you do it though because it would kind of take the character away from the Mercedes, after all fitting a chevy engine. I'm no fanboy but it just wouldn't seem right. If done though it would be one hell of a beast....emphasis on HELL
Old Apr 2, 2012 | 02:34 PM
Toadster's Avatar
2005 E55 AMG
maybe he means M113 motor mods?
Old Apr 2, 2012 | 04:16 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
5.5 bored and stroked as much as possible. All forged.
Cams ground to match.
Custom designed 4 valve per cyl heads
Completely redesigned intercooler system.
Largest Whipple you could fit under the hood along with massive bore TB.
All nice and neatly dyno tuned to race gas.
That would make me a happy camper.
Old Apr 2, 2012 | 04:34 PM
Sher Judge's Avatar
2017 991.2 Turbo PDK 2017 C63S Coupe Ceramic Brakes 2015 CLS63S AMG Full House
+ 1000 000
Old Apr 2, 2012 | 05:17 PM
chawkins2001's Avatar
2006 E55 AMG
I would go with the 2013 GT500 Motor with a 4.0 Whipple, and a built auto tranny with a monster stall.
Old Apr 2, 2012 | 10:05 PM
e500slr's Avatar
THIS.
Old May 5, 2012 | 01:18 PM
AMG903L's Avatar
2004 E55 AMG
Buy a spare E55 and drop it off to Nelson Racing Engines and tell Tom that money is no object. He would get you over 1000rwhp for sure. Maybe with the supercharger; but with twin turbos for sure. He has built many 2500hp street cars.
Old May 5, 2012 | 09:05 PM
Cylinder Head's Avatar
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
This. N/A is a different story (I'd take an M156 any day) but the M113 is no LSX.
Old Oct 12, 2012 | 09:12 AM
AMG903L's Avatar
2004 E55 AMG
http://youtu.be/y0s8Oz3QHNI
LSX TT
Attached Thumbnails Ultimate E55 Engine-ttdd.jpg   Ultimate E55 Engine-454tthr.jpg
Old Oct 12, 2012 | 09:30 AM
39NAS-T's Avatar
E55, TBSS, ZR1, ZL1
Seconded!
With a 3.8LC kb
