773hp & 925tq MHP E63 Tune Results
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
Tune results.
773HP & 925lb/ft SAE
618rwhp/740rwtq SAE on 93 octane
https://www.youtube.com/watch?v=-2DaHAnFL5Y
C218 CLS63TT PP Edition1, W213 E63S
618rwhp is 670 - 680 hp on the crank on new V8TT engines.
i wish some companies just show the diffrence in rwhp rather than guessing and assuming crank hp based on old drivetrain loss.
the new V8TT with MCT has 9.5% drivetrain loss and not 20%.
i am more into before and after only rwhp and rwtq.
don't give a F about any company claiming crank hp on these engines
2005 E55 AMG
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
![action](https://mbworld.org/forums/images/smilies/action1.gif)
![Violent](https://mbworld.org/forums/images/smilies/violent.gif)
x 1000
Not buying it....
925lbs tq? That would tear the trans apart plus there is no way they dumbed down that motor that much. How would you get enough to feed that thing with the stock injectors? Yes, I think you can get those numbers but certainly not from a simple tune.
The new E63 doesn't have the torque converter 7 spd. It uses a Multi-Clutch which I think they've beefed up severely. The new SL65 uses a 7 spd so you can tell it's strong.
Maybe I am just an old man but I can't see how you could get performance jumps like that on a tune? I just can't see how you would get enough fuel. Stock injectors and stock heads, stock cams? You have to get the mix into the cylinder first. I have a lot of experience with blowers but alas, I need to study up more on turbo charging. I very well could be wrong but I would like something concrete. I am sure it is around the corner. If it is true, and you can get that car to hook up at the track, it would be nuts!
Dirt Scooters
