Rear clunking?
Everytime I go over a speed bump or something similar, it sounds as if my entire rear is being lifted, then dropped.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
In my car, it is both air bellows that are making the same identical noise you describe. As per my local mb dealer, this is a very.common problem and can only be fixed by installing new air bellows.
The bags themselves?
