E55 Top Speed
No ones made a high speed run with a GPS to confirm speeds? I know people have as I've seen it mentioned and its common. What I don't remember is these people talking about the speedo being way, way off.
http://www.youtube.com/watch?v=OVsetfAYaxg
...and I said a modified E55 not a stock one like e55amgrocket's car. It has the power and torque so what can the gearing do for it to reach 225mph? ...and I wasn't talking about can you do it in a distance on the public roads I said can the car do it regardless of distance, in this case assuming it has a never ending straight.
If you want forget about the E55 even, let's talk the SLR because the gearbox is the same with the same number of gears but different ratios and tuning etc so can the SLR reach 225mph and again I mean the gearing not the power or the distance of the road.
if you really want to know what speed your doing you need a gps.
@32mph/1000rpm and an independent reasonably accurate rpm sensor one can verify the accuracy of their own speedo.
So for the video indicating 198.4 mph the rpms topped out at 6000. That's 192 mph.
You need to steer away from categorical statements that refute themselves
About breaking 200?
I say no one will build an E55 to do it. I dont say it cant be built I just say no one will build one that can, or find the road and space to do it.
I want to enter one of these - but don't want to hack the crap out of my car to run... They want cages, halon systems, battery disconnects, and quite a few other "permanent mods" that would make the car unable to be daily driven...
I am talking with one of the groups that puts on these high speed runs to see if I can register my 55 for an unlimited speed, exotic, limited production class that allows stock cars to run to an unlimited speed limit, without substantial irreversible modifications. If it goes through, I will have quite a long distance to stretch her legs - think 90 miles of pretty straight road to open the taps...
