Redbulljnky & Chawkins head to Silver Dollar Drags-April 28
#51
That baseline is not pump gas, Elliot had 110 in there before they added the Q16. That initial pull had some left over 110, and mostly Q16 in the tank.
Looks like they are at 545/582 right now.
#52
Nice gains so far!
#55
Not sure yet. Car is pulling timing at low end. Car thinks its too cold. Back to back runs and tank was still at 76 degrees. Might not need ice.
#56
Okay here is what we finished with today. And remember we are not done. But we are still at 550hp/599tq. AFR is bouncing around from 11.4-10.2. I was not happy with this. After we check the knock sensors we found out that the car was pulling timing at low rpms because it was too cold. Jerry then worked some of his majic and it started to straighten out but its still alittle rich from 200-4300rpms. The power band runs straight through redline. At 6000rpms we had 549hp and at 6500rpms we had 537hp.AFR still bouncing around but not as bad.
My cooling set up is alittle different. I have a Eurocharged HE with a Meziere pump, 3.5 gal trunk tank with a Rule2000 pump, 1.5 gal meth tank, and a Cobra HE mounted under the trunk. My system runs from trunk tank - supercharger - EC HE - C HE - trunk tank. The idea was to make sure that all the water being stored stays cold. And it appears to be working flawlessly. The meth sprays at 11lbs of boost, and is mainly for high rpms. My surge tanks are almost ice cold to the touch directly after a run. After one fourth gear pull to 186, the water in the tank was at 62 degrees. Ran another pull immediately and afterwards the water was only at 76 degrees. It was 97 degrees outside today.
We will finish tuning in the morning. Then I will jump on the road to SilverDollar. I will up date in the morning.
Thank you Jerry, Craig, Ahmad, Steve! All your help is much appreciated. Thanks guys!
#60
It will be up tomorrow. I left at 5:30 and didn't take a pic or print it. But I'll be there first thing in the morning.
Yes it is, mang. And thanks again!
#67
Dirt Scooters
So are you saying 50hp more than a previous race gas tune? Or you added like 2* to start the q16 tune on top of your pump timing then added 2 more degrees ending up at 4 and going from +2 to +4 degrees got the 50hp? And are we talking wheel? If so that is crazy and I need this fuel!
#68
Dirt Scooters
#69
Thanks Steve! The heat shouldn't be a problem. So we should be able to get a stong run in there. Expect the worst and hope for the best, right.
#71
There will be plenty of pics and vids, so stay tuned brotha's, it is going to get nasty
#74
Former Vendor of MBWorld
I have an event from 2-6pm....wish I could make it Good luck!
