Redbulljnky & Chawkins head to Silver Dollar Drags-April 28
Old Apr 28, 2012 | 04:37 PM
  #101
E55Dimon's Avatar
E63S
Ohhh nooo!!!
Old Apr 28, 2012 | 04:45 PM
  #102
zneB-sedecreM's Avatar
MB; 55KCL AMG, SL550 SLS AMG G500 Cabrio 280SL ML350 CLS550 ML500 E55 AMG CL500 S600 SLK32 AMG
Definitely not worth to it to me to blow the transmission for an 11 sec 1/4 mile... As long as you're happy thats all that matters Good luck getting it fixed RBJ
Old Apr 28, 2012 | 04:54 PM
  #103
blackbenzz's Avatar
haters crazy
You can get a used Trans for cheap and throw it in in a couple hours. Or send it off to get built but that's not cheap
Old Apr 28, 2012 | 04:55 PM
  #104
Ronan Mc Cabe's Avatar
Gone but not Forgotten 2006 E55 Renntech
BLEW THE TRANNY![/QUOTE]
That sucks
Old Apr 28, 2012 | 05:00 PM
  #105
320 dreamer's Avatar
2003 porsche 996 turbo
hooleyboy had his tranny rebuilt at renntech for 2500$ with upgraded parts. sorry it let go
Old Apr 28, 2012 | 05:01 PM
  #106
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
Could be something electrical going on. I wouldn't necessarily say tranny is trash. From what I was told, tranny won't engage gears when shifted like when it gets knocked in to neutral that some have experienced. Also rpms were hanging up instead of dropping when engine revved. Car did a fine 2nd pass then was shifted to 4th and coasted to end of track. After trying to get on throttle again it wouldn't go and restarting engine which usually fixes this type of no gear engagement issue didn't work and the rev hanging was going on.
A little odd to me that nothing messed up while on the gas, it was after throttle was lifted and car was slowing down at end of track.
Old Apr 28, 2012 | 05:06 PM
  #107
RedBullJnky's Avatar
you to Hate
Thanks David! I started drinking after the car did that so I got 2 pass down and 12 beers and 2 cigars down. But yes that's exactly it. Hopefully it is something stupid. There were no signs of any major damage. It just sucks!!!!!!!!
Old Apr 28, 2012 | 05:09 PM
  #108
you to Hate
On a side not the car weighed 3815lbs.
And a VERY BIG THANKS to Craig and Bart for helping me with the car.
Old Apr 28, 2012 | 05:15 PM
  #109
blackbenzz's Avatar
haters crazy
That's a ripoff. Adding a couple mb clutch packs for $2500 lmao! If you're going to build it do it right
Old Apr 28, 2012 | 05:34 PM
  #110
Forrest Gump 9's Avatar
shrimp boat
Ain't that a *****!!
The month of April had been bad to the E55k population. Let's be safe and ride it out.
Old Apr 28, 2012 | 05:44 PM
  #111
Hulk's Avatar
A Merc
You will bounce back, no one likes to see this happen to a E55
Old Apr 28, 2012 | 06:08 PM
  #112
Hammer Down's Avatar
2015 E63S, 2018 E63S
Originally Posted by RedBullJnky
On the second pass we ran 11.10 @126 and
BLEW THE TRANNY!
E, how many miles are on your car and when was the
Sat time that you had it serviced?
Old Apr 28, 2012 | 06:24 PM
  #113
e55amgrocket's Avatar
Dirt Scooters
Please guys park your E55's until Tuesday!!! Hopefully may brings better luck for us all.
Old Apr 28, 2012 | 07:39 PM
  #114
you to Hate
Car has 49k on the clock. Tranny was flushed 8k ago.
Guys, we don't really know what happened. It was on a good pass and when I tried to shift into fourth at the line it didn't. So I coasted to the end of the track and went to turn off and when I hit the gas nothing happened. So I rode around the corner and tried to get it into gear and nothing. I stopped the car and turned it off then back on and still nothing.
Craig and Bart came to see what happened and we tried everything. It just would not engage. We towed it back and Tony from BIP tried to help but still nothing. So we loaded it on the trailer and watched some other races and left.
We will figure out what happened when I get back to south FL. I'll make sure every one is informed.
Old Apr 28, 2012 | 07:40 PM
  #115
justinwrock's Avatar
Ducati
Sounds like limp mode.
Is there anyone with an sds local to you that can check for codes?
Hopefully it's nothing too serious.
  #116
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
+1
It could be limp mode. Unless tranny guts are all over the track
Old Apr 28, 2012 | 07:42 PM
  #117
blackbenzz's Avatar
haters crazy
Hopefully something simple like the conductor plate
Old Apr 28, 2012 | 07:49 PM
  #118
Ducati
Yep - shot a message to a friend whos an mb tech and he said to also check the 13 pin connector and fluid level.
Said "check for codes as it could be something like a wheel speed sensor or can-bus communication fault"...
  #119
you to Hate
Nothing spilled, no noises, no clunks, no jerks. Everything looks normal. It just won't go into gear.
The temp gauge on the cluster said that it was 102degrees on that second pass. I think we could have still hit 10s. It was pulling hard as FAWK. I was going to let Craig take the next pass. I'm glad it did this with me behind the wheel. Craig prolly would have sh*t himself if it did it to him. Lol. Oh well, that's the game we play. It will be fixed and stronger for next time.
Old Apr 28, 2012 | 07:50 PM
  #120
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Did you disconnect the battery for a while?
Old Apr 28, 2012 | 08:03 PM
  #121
NemoFoss's Avatar
94 yoda truck
Good run.. cant wait to see whats she does when shes fixed up.
Old Apr 28, 2012 | 08:23 PM
  #122
amx1397's Avatar
05 crossfire w/SL55 drivetrain installed by Rudy Compart Intake/Needswings best et-10.76 @ 129
good run,, Now i gota do more just to keep up. get it fixed for the 6th and run that 10.50. jim
Old Apr 28, 2012 | 08:41 PM
  #123
you to Hate
Yes. That didn't work either.
Thanks Nemo! We gotta figure out what happened.
Don't know about 10.5 , but we will try to be ready for the 6th. Sh*t if you lower your 60 and hook you'll be in the tens. But thanks Jim!
Videos of the runs and Bart's runs will be up Monday.
Old Apr 28, 2012 | 08:42 PM
  #124
kustom2k1's Avatar
03SL55
^^This^^
Old Apr 28, 2012 | 09:51 PM
  #125
novae500's Avatar
W211
damn RBJ, sorry to hear that. Hopefully its just a TCU upgrade issue or something else thats not too much damage.
