Redbulljnky & Chawkins head to Silver Dollar Drags-April 28
Old 04-28-2012, 10:01 PM
  #126
Former Vendor of MBWorld
Mike@Vossen's Avatar
AMG
Cool
Originally Posted by RedBullJnky
On the second pass we ran 11.10 @126 and .........
BLEW THE TRANNY!
Yeah I texted Craig and he told me the news. Had an event today otherwise I would have been with y'all.
I'm sure you'll be back running kicking *** and taking names in no time!
Old 04-29-2012, 08:01 AM
  #127
kompressede's Avatar
Sold - 05' E55
Man what a PITA - As you said it's part of the game, and I hope it's an easy fix.
You have a group of us that look forward to hearing about that 10sec pass.
Old 04-29-2012, 09:13 AM
  #128
FASN8N's Avatar
CTSV/6sp Grocery Getter
RBY,
It was good to meet you, your wife, and the beast yesterday. I am sorry that GA did not give you a 10sec time, but 90 degree weather and humidity did not help! I think Greg even saw 105-110 temps down near the track?
I think once you figure out the transmission gremlin and have some decent weather, you will blister the 1/4 mile
Old 04-29-2012, 09:49 AM
  #129
chawkins2001's Avatar
2006 E55 AMG
Here are some pics from yesterday and a vid of Elliots new personal best run. His car is a f*****g beast, period. I also dont think his tranny is blown, since there was no noise, fluid and anything out of the ordinary that happened after the run.
This is such a great forum as you meet really good people, and Elliot and his wifey Jessica are GOOD PEOPLE. Enjoy the pics!!!
Race weight with RBJ in the beast
New personal best, part of the elite few knocking on 10s door Weather condition at the time of the run was 90* and 1500DA....
Old 04-29-2012, 09:57 AM
  #130
Roverron's Avatar
ML63
Before throwing parts at it try a TCU swap and see what happens.
Old 04-29-2012, 10:04 AM
  #131
2006 E55 AMG
Good idea, I would also try putting the stock tcu tune back in.
Vid added up top!!!!!
Old 04-29-2012, 03:19 PM
  #132
RedBullJnky's Avatar
you to Hate
I'll let ever one know tomorrow what's wrong. Hopefully something stupid and easy.
Again thanks Craig for all your help.
Old 04-29-2012, 03:25 PM
  #133
Hulk's Avatar
A Merc
I'm sure it will be ok...
Are you back in FL?
Old 04-29-2012, 04:04 PM
  #134
you to Hate
Just got off 75 and now on the turnpike outside Orlando.
Old 04-29-2012, 04:05 PM
  #135
Hulk's Avatar
A Merc
Ok bro
Old 04-29-2012, 04:52 PM
  #136
2006 E55 AMG
Sure homey, I am pumped I could be apart of your PB charge of 11.03
Old 04-29-2012, 05:45 PM
  #137
BenzoDoc's Avatar
2015 E63S 4Matic
I was so sorry to hear that 10's didn't happen yesterday, I was at the EC open house when we got the news and Jerry called. You had a lot of Texans pulling for you at the meet, that's for sure.
I do hope that it is something benign...and those #s with ambients that high...impressive.
Old 04-29-2012, 11:22 PM
  #138
you to Hate
Thanks, its comming, for sure.
Originally Posted by FASN8N
RBY,
It was a pleasure meeting you as well. Thanks for all your help!
Will do.
I'm glad you were there. Thanks for everything!
Thanks mang! Tell the Texas boys I appreciate it. We will hit our mark, I know it.
Vids up in new thread.......
Old 04-30-2012, 11:12 AM
  #139
SPONSOR
loungn14's Avatar
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Exact thing happened to me in the C32 when I had it...
Connector plate was jaked and I was low on fluid. Correct me if im wrong here boys, but I am pretty sure that you need to check the fluid refill on flush with the car in D and not P. I had mine done right before the track, and low and behold the low level caused havic on the tranny and left in limp mode.
Old 04-30-2012, 11:30 AM
  #140
2006 E55 AMG
I think Elliot said he just had his flushed recently too before the strip, maybe this is what happened. He just pulled a code of P220a so far, but I am not sure if that is related to the tranny issue, as the CEL only came on later on in the afternoon.
Old 04-30-2012, 11:41 AM
  #141
2006 E55 AMG
Code P220a means:
Fault codes indicate that the speed sensors in the transmission do not agree with one another. Is caused by a faulty speed sensor. The sensors are part of the transmission conductor plate. Most likely the conductor plate needs to be replaced. There is an sensor at the front of the transmission that should be inspected for fluid contamination. If the connector has fluid inside it should be replaced and the codes erased and road tested. Of course the tranny fluid level should be the first thing that is checked.
The conductor plate contains the speed sensors. To check the plug he just needs to disconnect it at the transmission and check it for fluid contamination.
To replace the conductor plate the transmission valve body needs to be removed from below. The conductor plate is mounted to the top of the valve body. It's approximately $650 to replace the plate along with the connector.
If the plug is wet you do the plug first and road test it.
Let us know if this helps, it looks alot like what Jake described, plus what you experienced after the second run, an outed sensor with no catastrophic sounding damage.
Old 04-30-2012, 11:45 AM
  #142
you to Hate
Thanks Jake and Craig!
Old 04-30-2012, 11:53 AM
  #143
SPONSOR
loungn14's Avatar
no problem....you have a trans dipstick to check the level?
Old 04-30-2012, 11:58 AM
  #144
you to Hate
No
Old 04-30-2012, 12:00 PM
  #145
SPONSOR
loungn14's Avatar
No
mb has a special "tool" to check the trans fluid level. Its just a regular dipstick, just long etc as you can't check the levels without it. I have one at home I can loan and ship ya if you need it...
Old 04-30-2012, 01:04 PM
  #146
you to Hate
Thanks Jake, much appreciated! Let me check with Nemo and see what he's got first. He's already working on the car. I'll let you know.
Old 04-30-2012, 01:11 PM
  #147
tri-star tech's Avatar
2004 CLK55
That code can also mean your transmission is slipping. Considering what the car was being asked to do, i would go with the transmission slipping Bite the bullet and get a trans from a V12. More clutch packs from the factory.
Old 04-30-2012, 01:20 PM
  #148
e55amgrocket's Avatar
Dirt Scooters
could have something to do with that huge burnout. I did a huge burnout and had something similar happen but disconnecting the battery fixed it for me.
Old 04-30-2012, 01:27 PM
  #149
you to Hate
Now there's an idea.
Tried that at the track, still nothing. That was a crazy burn out though.
Old 04-30-2012, 02:47 PM
  #150
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
Elliot do like I said to check the fluid, use any trans dipstick from another car. Stick in until it bottoms out, just make sure it gets all the way to bottom and hits bottom of tranny pan. Check it with car running and in neutral. These are measurements to use at different temps. Measure up from the end of the dipstick and be sure the level is correct.
70 F = 25mm on the stick
90 F = 35mm on the stick
170F (fully warmed…about 15 minutes driving) = 65mm on the stick
And changing the electric plate is easy, I can do it in 1 hour and it is $250 from dealer or cheaper online and I have that brand new one sitting in my garage. Then it will take 4 quarts to fill tranny fluid back to proper level if it was at correct level before. Use the proper fluid also for the 722.6
I made that good tranny thread on the other site with lots of info.
Quick Reply: Redbulljnky & Chawkins head to Silver Dollar Drags-April 28
