TTM and ARH do it again!!!! E55/CLS55 1-7/8" LONG TUBE HEADERS sneak peek!!!
Positive:
1. No check engine light.
2. Awesome built quality.
3. Sound is amazing!!! Not loud at all. You can not tell that they are there if the car is idling. Once you open her up is completely different story, but again NOT very loud.
Negative:
1. Since the primaries are 1 7/8 there are NO Gaskets for the heads. I used some high temp silicone. ARH told me that when the get the MLS gaskets made i will receive them immediately.
2. The steering shaft joint connection bolt rubs on the header. For the life of me I couldn't make it not to rub. The only way would be to create a small dimple on the header so I can prevent contact with the shaft.
3. I used TTM 90 degree O2 elbows and extenders so the O2 harness was not extended BUT you will HAVE TO extend your oil sensor harness at the bottom of the oil pan. Look at the pictures. There is no other way.
Thanks for the feedback,this is what I've been waiting for..The positives along with the negatives..Did you happen to do some before and after dyno pulls??
I've been trying to figure out what my vibrations issues have been since the installation of the ARH LT. When I toe into WOT I feel this vibration like the headers are hitting something on the frame. I've checked and double checked... I thought it might be something regarding the rubbing of the tubes..
Also the #1 tube is rubbing against a heat shield...I can see the marking on the tube. There are 3 spot on the left header that are rubbing under full load. BTW my engine mounts are brand new so it not the problem. It just a bad design.
Do not waste your time modifying the bolt. I wasted 2 full days trying all kind of different things with no luck. It still rubs big time under load and on left turn. My mounts are brand new as well. I do have the 55K engine and yours is the 6.3 but i highly doubt it you will be successful by just trying to adjust/change/modify/replace/etccccc the shaft bolt and bracket.
