--DIY Vented upgraded Seat Fans--
Rating: Thread Rating: 10 votes, 5.00 average.
Old Aug 15, 2015 | 08:21 PM
  #101
RJC's Avatar
RJC
Various
Question
Has anyone conquered the seat bottoms yet? I posted way back on this thread that if a hole was cut on the top of the floor duct running under the seat and blocked the rear facing opening with foam, theoretically it should blow cold air (when ac set to bi-level) right up into the seat bottom/fans. Someone said they tried it but the lower cushion fans pull air vs push, if that's the case can't they just be flipped over?
Thoughts?
Old Aug 19, 2015 | 08:26 PM
  #102
RJC's Avatar
RJC
Various
^bump^
No one's done the bottom cushion yet? Is it that difficult to remove the seat?
Thnx
Old Oct 10, 2015 | 08:31 AM
  #103
berti_00's Avatar
2016 Cls63s AMG
I have these new B-blasters fixed up and ready to install on your seats. I sold my car and selling things. They are brand new. It took me quiet a while to get them perfect
--DIY Vented upgraded Seat Fans---20141209_154059_zpspjtze9un.jpg[/QUOTE]
Old Oct 17, 2015 | 05:29 PM
  #104
berti_00's Avatar
2016 Cls63s AMG
if anyone wants these fans let me know... i have them ready and i can ship them
Old Oct 18, 2015 | 12:19 PM
  #105
viper04's Avatar
Berti
What do you want for them. Thanks.
Old Oct 18, 2015 | 01:04 PM
  #106
AndreNY's Avatar
couple of Benzos
how much you want? im assuming they will fit a CLS, too bad I didn't see this before I was just in Clearwater I could have picked them up from you
Old Oct 18, 2015 | 03:58 PM
  #107
berti_00's Avatar
2016 Cls63s AMG
yes they will fit a cls
Old Oct 20, 2015 | 07:31 PM
  #108
berti_00's Avatar
2016 Cls63s AMG
*******FANS SOLD thanks
Old Oct 22, 2015 | 04:04 PM
  #109
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
Thoughts?
I was thinking this also...and actually possibly adding some flex ducting to direct air from floor board vent into the seat. the fans should be able to flipped over, but yeahhh...not sure if anybody has done bottom fans yet as they are a bit more involved.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Apr 24, 2016 | 12:45 PM
  #110
coolgenner's Avatar
2005 E320 CDI
Another one upgraded.
Thanks for all of this information. I did my 2005 E320 CDI this weekend. I am very slow,it took an hour to cut 8 corners, took an hour to get the old fans out and disconnected, it took an hour to widen the holes and another hour to solder, install and cleanup. But those four hours made me the happiest I have been in a long time.
Totally worth the cost and effort.
Old Apr 25, 2016 | 09:48 AM
  #111
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
I've tried several different fans mentioned in this thread.
These are definitely the best value
Amazon.com: Vantec TD9238H Tornado 92x92x38mm Double Ball Bearing High Performance Case Fan (Black): Electronics Amazon.com: Vantec TD9238H Tornado 92x92x38mm Double Ball Bearing High Performance Case Fan (Black): Electronics
$15 and flow better than the BGears and the ones Berti linked.
Old Apr 25, 2016 | 03:53 PM
  #112
hachiroku's Avatar
SPONSOR
hows the sound level?
one amazon review states...
4.0 out of 5 starsThe 80 mm version seemed better balanced
By 68redcedar on April 28, 2013
Verified Purchase
I use these as fans in a Camper Van.
I first bought the 80 MM version of this fan and put it on a voltage based speed controller. That was nearly silent on 3 volts and sent a dense narrow column of air on 12 volts across the van. 9 and 7.5 volts still moved a good amount of air without an ear bleeding volume.
So happy was I with the air moved, I bought this 92 MM version, and while it does move more Air, it is not that much more air. It produces a less high pitched roar at 12 volts than the 80mm version, but does not seem to move all that much more air. At lower voltages it is louder than the 80 mm fan, and vibrations are obvious whereas the 80 mm fan is much less so.
Either way both fans move air in a dense column in a straight line with no hotspots as other fans do, and at wider angles. They are loud, but with a speed controller can be suited for most any condition. If they made a 120mm version, I'd be all over it.
4.0 out of 5 starsReally Blows! And It's Loud!
By Russ H. on January 27, 2014
Verified Purchase
I'm sure if I had a decibel meter I could quantify the insane whine that comes out of these guys. But I don't have one. So I'll just say that it's FREAKIN loud!
That said, these guys move a TON of air. I chopped the voltage down by rigging the fan up to a USB adapter wire (don't ask) which cut down the sound considerably. Still moves a lot of air and now I can just unplug it when I don't want to hear it.
__________________
-BARRY
Old Apr 26, 2016 | 10:02 AM
  #113
BagMan's Avatar
Louder than the others at level 3, but not that much. Quiet at level 1.
I'm not sure what voltage is supplied to the fans at each setting. I don't think it ever gets a full 12v.
Old Jun 14, 2016 | 10:01 AM
  #114
ForKyleigh's Avatar
2004 E55 AMG
I know this thread it is old but it is by far the most pertinent. I just got done doing this mod last night. Or so I thought. One fan works great. When ever I give the 2nd fan power, all of the seat fans go off. I have switched the fans, it is not specific to the fan. I feel like there is to much current draw and it is killing the power because of it. They are rated at 12v. Rated current is .62a. They are the same fans that the person sold in this thread by the looks of it. Any help would be appreciated.
Old Jun 14, 2016 | 10:28 AM
  #115
BagMan's Avatar
I'd double check the wiring for a short or polarity
Old Jun 14, 2016 | 10:31 AM
  #116
ForKyleigh's Avatar
2004 E55 AMG
I should have clarified that, apologies. Polarity is correct! I made sure of that. It is pretty hard to have a short as well. There are only 2 wires to splice and I hooked up the other fan first... and then that when I hook up the fan that was originally working it shuts down the hole seat. It is definitely related to having them both running.
Old Jun 14, 2016 | 11:15 AM
  #117
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
Did you try switching them both to low and medium and see if they work? Mine is rated at 0.5A each and I can have both running at the same time full blast. If you have an SDS scanner, you could possibly check for faults or events that indicate what might be happening. I will be doing this upgrade again in the near future on my other W211.
Old Jun 16, 2016 | 11:33 AM
  #118
ForKyleigh's Avatar
2004 E55 AMG
Ok, more information on my issue. I am using the B-Blasters. So, they are they same as most people. I was using the 12v and the signal wire soldered to the 12v from the car. That was the only way I could get the fan to work. But you guys are only using the 12v and the ground by the looks of it. I changed my wires to match this. When the 90mm b-blasters are wired this way, they turn on and run for a few seconds and then stop turning. If I did connected the 12v or the ground and reconnect they will do the same thing, turn for a few seconds then stop. Has anyone had this happen? I have verified that voltage remains constant with a volt meter. So the power and ground are still there, but the fans stop. I will probably had to order new fans. But I dont know that i want to order the same if I would possibly have the same issue.
Old Jun 16, 2016 | 01:21 PM
  #119
turbo97se's Avatar
Check my post #76 (at the end) on the wiring. There are 3 wires usually on B-Blasters - power, ground and speed signal. Maybe make sure you are connected correctly and not to the speed signal. I am unable to understand exactly how you have it wired but should just direct wire to the original fan wiring. I forget if it is always 12V since it is variable speed from the control switch, it should be 12V on the first press of the switch and something lower voltage when pressing a second/third time.
Try connecting the fans directly to a fused 12V battery source and see if they stay running.
Old Jun 16, 2016 | 01:33 PM
  #120
ForKyleigh's Avatar
2004 E55 AMG
Direct to a battery does the same thing with using the 12v and the ground. The fans I have are 4 wire. I just looked, they don't appear to be b blasters, sorry. They are b gears. here is a link....
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
So there are ground, 12v, signal, and an rpm wire I am assuming. I am trying to use the ground and 12v. Maybe these fans do not run at 100% with just the ground the and 12v hooked up. I have emailed the company but havent received a response.
Old Jun 16, 2016 | 01:48 PM
  #121
turbo97se's Avatar
Looks like the fans you got may need a PWM INPUT signal. You could possibly try hooking up the PWM wire to 5V constant (and bump up to 12V) or GND (try GND first) and see if it works. There's not a lot of info out there on your fan.
Old Jun 16, 2016 | 04:14 PM
  #122
ForKyleigh's Avatar
2004 E55 AMG
At 12 volts to that pwm wire, it does turn on and run. It runs at all three settings for the vented seats. BUT, I can only run one fan. This was the original post I had talked about. When I hook up the second one, all the fans turn off (seat bottom included). That is why I wondered about to much current draw.... it even kills the seat bottom fans. maybe I will just order some b blasters and move on.
Old Jun 16, 2016 | 05:08 PM
  #123
ForKyleigh's Avatar
2004 E55 AMG
Can anyone verify the voltage going to the fans at the highest setting. My volt meter is showing under 11 volts. I just want to make sure this is correct.
Old May 16, 2017 | 06:41 AM
  #124
rbul's Avatar
W211
Can you update your photos?
Old May 16, 2017 | 09:05 AM
  #125
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
I think that this is a great upgrade, I know that I can't really feel the fans in my seats, unless I'm wearing a t-shirt. And I know that I could use it today, going to be 91-93 in Northern Virginia. Bring on the humidity
You have already rated this thread Rating: Thread Rating: 10 votes, 5.00 average.
