--Calling out all the CLS63 cluster swap guys-- need your help
Old Apr 2, 2013 | 05:48 PM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
im not sure if that would work, because the milage must be within 150 or so of your cars milage else you will just get the dashes, this would have worked if you swapped the boards when originally changing the clusters over as the milage would have been the same as your cars.
Old Aug 9, 2013 | 10:48 AM
gazosnic's Avatar
e46 m3, w211 e55
So based on this information - is the following correct assumption? If you swap the PCB from the original e55 cluster it would be plug and play from a used cls63 cluster?
Old Aug 9, 2013 | 04:13 PM
pas6201's Avatar
Former Vendor of MBWorld
2012 F150 FX4 Ecoboost, 03 e46 M3 (sold), 05 E55 (build is on), 03 Escalade (going to sell)
I am throwing a CLS63 cluster in my car. Just send the 63 cluster to Jerry and he can set it to 0. He did mine
Old Aug 9, 2013 | 04:31 PM
shardul's Avatar
2003 W211 E55, 2003 W220 S600
yes.
Old Aug 9, 2013 | 04:34 PM
gazosnic's Avatar
e46 m3, w211 e55
Originally Posted by shardul
yes.
Cool - thank you for the answer. Is there anyway to have the car coded to adjust since i have the older 160 mph speedo so a new one would be accurate?
Old Aug 9, 2013 | 11:21 PM
cij911's Avatar
one car at a time
So how does the new dash display the oil temp. (where is the dash getting the info) ? And what about TPMS monitoring each tire vs. just showing low ?
I would love to put this on the list of to dos
Old Aug 9, 2013 | 11:31 PM
  #32
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
The oil temp data was probably already there, since it all gets streamed in together on a low speed CAN line. The old cluster just didn't show it but the temp was always accessible with a STAR or OBD2 device.
Old Aug 9, 2013 | 11:38 PM
  #33
AMGPilot's Avatar
2004 E55
You have to change a adaptation in developer from Linear to non Linear, otherwise when you are doing 160 the speedo will show 200mph.
You will be accurate up to 80mph after that the error will increase as you go to full travel of the speedo
Old Aug 10, 2013 | 08:22 AM
  #34
cij911's Avatar
one car at a time
What other data is readily available and able to be displayed on the dash (all the time) ? Oil pressure, oil temp, and voltage (I miss having these three) ?
Old Aug 10, 2013 | 11:01 AM
  #35
berti_00's Avatar
2016 Cls63s AMG
i love my cluster
Old Sep 18, 2013 | 04:17 PM
  #36
Redw20855amg's Avatar
Blown 208 55 amg, 211 55 amg
pics installed?
Old Sep 18, 2013 | 05:07 PM
  #37
SilverStrk's Avatar
05 E55, 07 ML500
How much are you guys paying to do the swap??? Is it worth it in your opinion..
Old Dec 29, 2013 | 01:42 PM
  #38
EmDee's Avatar
04 E55
I recently updated my gauges with set from an E63. Sure enough, up to 120mph its spot on (checked with a GPS), but from 120 up, its off as I expected. The old E55 160mph gauges go up by 10mph increments every labeled tick from 120mph, where as the E63 gauges go up by 20mph increments from 120mph. So I assume you use a Star programmer to make this "linear" to "non-linear" change? Do you need the developers version to do this and which menu item is it under within Star DAS to make the change?
Old Dec 29, 2013 | 02:32 PM
  #39
berti_00's Avatar
2016 Cls63s AMG
Originally Posted by Redw20855amg
pics installed?
Old Dec 30, 2016 | 02:44 AM
  #40
spastik monkey's Avatar
Veteran: Army
Chevrolet Traverse, Honda Cbr1000RR
Has anyone reset theirs with the digiprog 3? The problem with swapping the boards is you lose all the cool new features.
