Power trunk sensor
Old Jun 10, 2012 | 11:32 AM
cij911's Avatar
one car at a time
Power trunk sensor
My rear power trunk is acting up. At first I thought I had a short circuit or cut wires, but that is not the problem. I am guessing there is a sensor to tell the switch the trunk is fully open and capable of being closed and it needs to be replaced or adjusted.
If I just open the trunk, the power switch lights for a second and then turns off (and renders the power trunk useless). If I push the trunk just a little further (fully open), the switch lights up and can close the trunk fine.
If I use the switch on the drivers door, I can open and close the trunk fine. So I know the motor is fine, I know the wiring is fine, but there is something that tells the rear switch the trunk is open and that is NOT fine .
Any ideas how to adjust the sensor / switch ? Or replace ? TIA
Old Jun 30, 2012 | 11:20 AM
cij911's Avatar
one car at a time
Anyone ? Bueller ???
Old Jun 30, 2012 | 12:02 PM
baldmike73's Avatar
i was having the same problem - thought it was the power or sensor as the button inside the worked on mine too - just the button on the rear lid was not working, but when my shop took it apart the wires way in there were coming apart - once they resoldered and rewrapped its as good as new - he said it is starting to become more common as these cars are approacing 10 years old.
