Extra oil cooler for E63
Old Jun 23, 2012 | 02:55 PM
2008AMG63's Avatar
2008 E63, KTM990, 2012 CLS63, 1972 W108 280SE 4.5
Anybody tried this on a E63?
Or replace OE with bigger one?
Edit: OIL COOLER, not cooper!
Old Jun 25, 2012 | 03:30 PM
newlyAMG's Avatar
2007 E63 AMG
I usually run 99-100 degrees C while driving normally, 106-108 after a quarter mile pass, never seen it north of 110, what do your temps look like?
Old Jun 25, 2012 | 03:42 PM
infantry's Avatar
07 E63. 07 STi limited #606/800
Ha! Newly AMG you live in a colder climate!
Here in Phoenix Arizona!
I also usually run 98-100*C while driving normally!
A quarter mile pass here results in 108 or so as well, but i've gotten my oil temps all the way up to 117*C before!
Old Jun 25, 2012 | 03:53 PM
newlyAMG's Avatar
2007 E63 AMG
I know you guys put up higher numbers on the thermometer, but man you've gotta wrap up in a wet blanket THEN go outside to get a taste of this humidity! Worse when I lived closer to Va. Beach!
Haha my back-office folks are out in Phoenix, we have that argument of "who's got it worse" all the time.
I used to stress to see the temps go up but I just read in another thread that up to 140 is apparently ok, so flirting with 110 should be fine. Car ran suprising well in 4 back-to-back (-to-back-to-back) passes, then I heat-soaked my buddies E55 after 15 minutes in 90+degree humidity, glad I went with the N/A 6.3 over the blower setup, less finicky, still hauls ***!
Old Jun 25, 2012 | 06:50 PM
2008AMG63's Avatar
I was really worried running oil up to 117C sometimes .. I was confrimed by the dealer its completely normal and can withstand 140C peaks (that a red light will warn excesive oil temps.)
Water temp always normal.
The heat coming from the engine bay and sorrundings is pretty amazing! .. I think half of my tyres wear is because of this.
Anyhow, I was wishing there was an oil cooling mod for the 63s!
Old Jun 25, 2012 | 10:00 PM
infantry's Avatar
Anyone know exactly where the oil cooler is located? Is it the one when you open the hood, on the right mounted on the front of the radiator? Or is that the AC one?
Old Jun 25, 2012 | 10:41 PM
2008AMG63's Avatar
The oil cooler is located on the right side, behind the fog lamps.
You can see it tru the fog lamp grill.
Old Jun 26, 2012 | 01:28 AM
Hasan Shaikh's Avatar
E63s - AMG and M6
My car also runs rather warm.
During normal driving the oil temp remians between 103C to 105C.
If I push it it goes upto 120C.
But all of this is on road driving. Not sure how hot it will get on track.
Old Jun 26, 2012 | 11:57 AM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
normal is 100-108 hard I am seen 117 never pass
what I have a problem with is i never hear the fan for that oil cooler.
I the fan never on.
I am tempted to disconnect it and put power making sure it is working.
Old Jun 26, 2012 | 12:12 PM
2008AMG63's Avatar
I the fan never on.
I wouldn't do it!
Are you getting sustained high oil temp?
I am searching for some diagrams, trying to figure out if there is a fan or its air cooled only and found this: https://mbworld.org/forums/c63-amg-w...ooler-fan.html
Old Jun 26, 2012 | 05:58 PM
SuperchargerV8's Avatar
03 e55 amg
I have an 03 55K which does not have the oil cooler under the h/e would fitting one help my water temp or anything like that will it do anything ?
Old Jun 26, 2012 | 10:30 PM
2008AMG63's Avatar
Im not familar wiht E55s, but theorically a S/C would benefit more with a bigger Intercooler (H/E) .... So if the oil temp is not an issue you may use the area for an extra or bigger H/E....
Old Jun 27, 2012 | 04:53 AM
03 e55 amg
How can i check my oil temps ? where should i look ?
Old Jun 27, 2012 | 06:40 AM
newlyAMG's Avatar
2007 E63 AMG
We've got an extra menu in the 63 that you guys in the 55s don't have, shows oil temp, voltage, and I think a race/lap timer. I think with the 55s it's probably just dummy light or no dummy light
Old Oct 25, 2015 | 12:41 PM
WideLowandFast's Avatar
I the fan never on.
I believe the fan kicks on above 108-110 degrees. I'd often hear it at stoplights, this past summer.
