Best radar/laser jammer to buy?
Old Sep 22, 2012 | 11:31 AM
Toadster's Avatar
2005 E55 AMG
so if you're the only car on the road, and CHP sprays you with his Lidar and cant get a reading... does he pull you over?
Old Sep 22, 2012 | 11:44 AM
cij911's Avatar
one car at a time
Yes and he politely asks if he can buy you a donut ....
Old Sep 22, 2012 | 01:31 PM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Originally Posted by cij911
AgSilver - Why not mount them higher ? I am trying to get confirmation of the spread, so I can determine the optimal mounting points (a sales person thought 18" - which is not a lot).
Works perfectly as installed. Laser beam width at 1000' is at a minimum 3' and they always aim for the headlights or front license plate (if you have one). Those fancy computer designed, expensive projectors we have are great reflectors, but the transceivers are always well within 3' of the headlamps and the scatter is all over the place.
Old Sep 22, 2012 | 02:27 PM
KeepRtPassLeft's Avatar
1970 220D
Originally Posted by AgSilver
Look just above the heat exchanger.
They are too low. There is no benefit placing 4 there vs placing two there. There is a problem with some of the new Blinder HP-905s. When using three or four heads plugged into one CPU, vs LIDAR guns that operate at 125pps those are the LTi ultralyte series and the LTI Marksman, get significant punch throughs. When using two heads this doesn't happen. Blinder is currently trying to remedy this issue. http://www.radardetectorforum.org/sh...ad.php?t=14156
You should get your setup tested.
Old Sep 22, 2012 | 02:45 PM
cij911's Avatar
one car at a time
How would someone get their setup tested?
Old Sep 22, 2012 | 03:01 PM
1970 220D
Where are you located? You can pm me if you don't want to post it.
Old Sep 22, 2012 | 07:20 PM
  #32
AgSilver's Avatar
All I can say is that so far it has proven itself to be effective in the field on many occasions against tripod mounted, hand held and stationary automatic systems. I've updated the processor twice via Blinder's URL I am assuming that all 4 transmitters fire simultaneously no matter which transceiver gets the hit. Between that and a Bell RX65i, and a little common sense, I feel pretty safe.
Old Sep 22, 2012 | 08:04 PM
  #33
cij911's Avatar
one car at a time
KeepRt - I signed up for the radar site you suggested, but cannot post there yet...
I ordered the dual hp-905, but now am wondering if I should have gone with LI dual. Does the LI dual protect against all LIDAR ? Where is the an unbiased review ? How could I get my setup tested to validate how good it is ?
Old Oct 1, 2012 | 09:12 AM
  #34
cij911's Avatar
one car at a time
Can someone please post pictures of the front sensors installed on the e class ? I am having a hard time getting the units mounted and perfectly true and level. Thanks
Old Jan 12, 2014 | 11:05 PM
  #35
Redw20855amg's Avatar
Blown 208 55 amg, 211 55 amg
Just tell him officer my car says "*fu*ck* the police" can you see it? (your heat exchanger)
yes i know old post but i had to revive it.
I rock a jammer no complaints I love it saved me countless times, probably will buy a valentine one to add to the mix this year just because they are insane i love them...
Mine are mounted behind the grille on my heat exchanger its dark outside otherwise id go take some pictures
Old Jan 12, 2014 | 11:07 PM
  #36
Toadster's Avatar
2005 E55 AMG
Valentine One
Old Jan 13, 2014 | 01:13 AM
  #37
act1v3x's Avatar
55k FTW
Just buy directly from them... $400 plus shipping. https://store.valentine1.com/store/
Old Jan 13, 2014 | 01:15 AM
  #38
AMGAffalterbach's Avatar
2014 BMW M235i
In the famous words of everybody from Motor Trend and The Smoking Tire, the only radar detector that works is the Valentine 1
