Pulley fell off, sheared woodruff key, FIXED
Old 06-26-2012, 10:16 PM
nizzle's Avatar
2014 AMG E63S, 2006 XK8 victory edition convertible, 2006 supercharged trailblazer SS, 2001 E430
I did 3 short WOT runs where I had space as I was out running errands. I came back and checked the markings on the pulley & crank bolt. Everything appears to be holding just fine! I will do more runs and post up when I do
Old 06-26-2012, 10:32 PM
jcjmw's Avatar
2005 E55 Wagon
Alright!!!
Old 06-30-2012, 02:08 PM
nizzle's Avatar
Another update,
Did a few more WOT runs and a nice parking lot smoke show and everything is still holding tight. I marked the Pulley & bolt so I could see if it the bolt ever starts to back out. It has not budged not one centimeter
Old 06-30-2012, 02:38 PM
novae500's Avatar
W211
Great fix on your part! Good results where others weren't so lucky
Old 06-30-2012, 03:58 PM
nizzle's Avatar
Thanks. I saw what GT-ER had done and it made sense to me. It worked for him and now it's appears to be working for me as well. I will keep posting as time goes on to keep you all updated.
Old 06-30-2012, 05:24 PM
GT-ER's Avatar
2005 E55 AMG
Woohoo...that makes two cars with the home remedy working well. Maybe people should start doing this PRIOR to installing the pulley the first time. It may avoid headaches.
Old 04-08-2013, 03:31 PM
  #32
mikkee's Avatar
g55
How has this fix been holding up? Just in the same boat and trying to figure out options.
Old 04-08-2013, 03:56 PM
  #33
layzie12g's Avatar
2008 Mercedes Benz E63
I have a customer who is also in the same boat. We are going to use a BIP pin kit to remedy the problem permanently.
Old 04-08-2013, 03:59 PM
  #34
mikkee's Avatar
g55
What is the BIP pin kit?
Old 04-08-2013, 04:35 PM
  #35
chawkins2001's Avatar
2006 E55 AMG
I (BIP) will pm you brotha.
Old 04-08-2013, 05:04 PM
  #36
layzie12g's Avatar
You (BIP) should start a thread showing your product. I just ordered one.
Old 04-08-2013, 05:35 PM
  #37
typhoon43's Avatar
Location: Gainesville, FL: In a garage or in a bar, or a garage with a bar in it.
2005 E55, 2011 Honda Push Mower (21 inch deck bishes)
Go ahead and make that a double please sir <grin>
Should be picking up my E55 on Friday and I'm doing every piece of research and jotting down every preventative tip/product I can find.
Old 04-08-2013, 05:43 PM
  #38
mikkee's Avatar
g55
this is what my snout looks like:
My dealer is recommending rebuilding the engine since they are worried the crank might be out of balance.
Old 04-08-2013, 07:52 PM
  #39
e55amgrocket's Avatar
Dirt Scooters
Who installed it? I feel your pain I've been thru that and its not fun (or cheap)
Old 04-10-2013, 02:12 PM
  #40
Dirt Scooters
any updates?
Old 04-10-2013, 02:45 PM
  #41
Manuyc's Avatar
06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
Ok so here is the VERY short version of a VERY long story. My pulley fell off (wasn't torqued to the +90 & wasn't my fault... don't ask) and sheared off my woodruff key. Didnt want to have to remove the timing cover, chain, gear, etc. to fix it. SO, did some research and found a good solution (IMO) for a fix. Thanks to GT-ER, Shardul, Chawkins and everyone else who chimed in with good info, ideas, and support. Sorry for the HUGE lack of details but it would be nothing short of writing a novel to explain the whole situation. Anywho, here are a couple pics.
drimmeled out the end of the crank a little
Then JB welded in a super strong piece of steel (not sure the exact kind/grade) bolted the pulley up and torqued it down CORRECTLY and...... as good as new or better IMO
dam i should have had you fix mine when the pulley sheered my keyway. it cost me 2700.
Quick Reply: Pulley fell off, sheared woodruff key, FIXED
