Pulley fell off, sheared woodruff key, FIXED
2014 AMG E63S, 2006 XK8 victory edition convertible, 2006 supercharged trailblazer SS, 2001 E430
Ok so here is the VERY short version of a VERY long story. My pulley fell off (wasn't torqued to the +90 & wasn't my fault... don't ask) and sheared off my woodruff key. Didnt want to have to remove the timing cover, chain, gear, etc. to fix it. SO, did some research and found a good solution (IMO) for a fix. Thanks to GT-ER, Shardul, Chawkins and everyone else who chimed in with good info, ideas, and support. Sorry for the HUGE lack of details but it would be nothing short of writing a novel to explain the whole situation. Anywho, here are a couple pics.
drimmeled out the end of the crank a little
![](http://i1080.photobucket.com/albums/j331/seattleNATEive/fb6319a0.jpg)
Then JB welded in a super strong piece of steel (not sure the exact kind/grade) bolted the pulley up and torqued it down CORRECTLY and...... as good as new or better IMO
![](http://i1080.photobucket.com/albums/j331/seattleNATEive/d2fb39f3.jpg)
Not only did the pulley falling off shear my woodruff, but it also made my sack shrink (lol JK). I'm still a little too nervous yet to do a wot run. Lemme grow some ***** back and I'll do a couple wot runs and let you know if it holds.
CLS55
Been wondering for those who had this all go bad on them ... Perhaps the end of the crank snout can be machined to a spline / rib profile and a blank ring fitted over it , to shim to oem size/ spec or have a pulley machined to match the spline... Mbe there is a reason this is not done already but just a thot ... Of course means some pretty high tolerance engineering and crank out the motor ...
Obsidian Black E55
Back in school my instructor told my always to use a bit of loc-tite on crank bolts. Come to think about it i dont think i ever have though. Ive never had a single car come back for a loose pulley either.
I think if i ever do take the crank pulley off this car, i think i may put a bit of blue loctite on there just to be on the safe side..
If it is not torqued right, loc tite will not help at all. Had 148 ft lbs & loc tite on it when it fell off. The +90 on our crank blots after the 148 ft lbs is everything
Obsidian Black E55
Yeah thats a given. Its a torque-to-yield bolt, without that 90 degrees its going to come loose.
I think your fix will hold up just fine, assuming that is the crank bolt is correctly torqued! Good luck!
Sorry to hear that. I am starting to think that this problem is more common then anybody knows. Luckily, GT-ER came up and shared his solution which seems the easiest and best solution. If you need help, just ask and I am sure anyone here will offer whatever they can to help you.
i guess technically it could be but the car feels fine. I dont notice anything negative
Dirt Scooters
We have JB weld on a engine block on a excavator at work that has held up since 2003 (I remember putting it on the week after i graduated high school lol) Still hasn't leaked to this day and its had another 2000-2500 hours put on it. That stuff is great!!!
I put a mark on the bolt and the pulley so I can check to see if the bolt appears to be backing out/loosening, and it has not budged at all. I have done some good power runs but I am waiting for the weather to clear up in the next day or 2 for a couple WOT runs.
