722.6 B2 shift valve
I'm hoping someone can confirm something for me though.
What is the orientation of the B2 shift valve? does the metal cup face into the valve body or out of it.
This is the odd valve that is held in by a pin.
Thanks alot!
Most of the solenoids have a little nipple with an o-ring on them that goes down in the valve body and then I can't remember exactly but there are one or two with a shaft that goes down in.
But this is not a solenoid it is a valve. The B2 shift valve. It is on the side of the lower valve body. It is not held in by a plate like all the other valves it has a pin that slides in from the top. The diagrams are not detailed enough to determine the orientation of the outer metal "cup" for lack of a better term. The valve itself is made up of three pieces, valve, spring and this metal cup.
All the valves are held in by the end plates that hold the springs in, some the big springs and some the little ones with the little aluminum pieces seen in pic. I must be losing my mind about one held in with a pin. Also, you mention "B2" but when I look at a pdf file of the valve body "B2" is listed as "Brake control solenoid valve B2."
Also this would be the "top" of the valve body when it is out of the car, but bottom when installed
When you say "bottom of valve body" are you refering to this part? Or the other half that is bigger and would be the part sitting down if it was out of the car?
And also where at in pic 1 or pic 2 is this part located? Like I said, I took my valve body out at one point, took all the solenoids out, split it in half and pulled the plates off that hold all the plunger valves in on both halves of the valve body but don't remember any pin holding anything in so am confused.
Looking at my pic I don't even see where that pin would be, crazy stuff!Either way, maybe post a pic of the piece you are trying to figure out how it goes in? If I can't help maybe someone else can, can't remember the screen name off the top of my head but there is another member that has tore his tranny apart and also taken valve body apart so he probably knows.
