How many of you daily drive with a 180mm and higher crank pulley?
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
It is pretty sad that my car has trapped 120mph when it was 60 degrees but when I went to the track on a day around 90 and high humidity I could only run mostly 112 with two 114mph runs. That is a HUGE loss in performance and I have a CM30 pump and Eurocharged heat exchanger as well as a little seperated coolant tank, so "you just need cooling" can't be said. I mean there are guys with all the bolt ons that have ran over 120 with the 168 and even the stock pulley for that matter.
If you are in any kind of climate that actually has hot weather and for a prolonged timed out of the year to compound that, it just isn't worth for a daily driver to have the 180. Doing dyno pulls you can see the power loss that you will basically see on the street, so having the the big pulley does you no good after one gear pull, for example I can lose 30+ wheel hp from a cool run to a run where the car is actually warm like it would be out driving so any extra that 180 would give you, you probably just lose and could have more consistent power with a smaller pulley.
That 180 or bigger comes in handy strickly for a car that is gonna sit in a parking lot for 45 minutes and get cold with ice on it, then have ice flowing through a tank going to the intercooler and have one single glory run then be back where it started again sitting with ice on it again. This is obviously not realistic for a "daily driver" since you aren't going to be doing that driving around. So in my opinion that performance you are seeing from some car with a 180 at the track doing all the mentioned above is giving people a false impression of what to expect with a 180 unless they have an improved intercooler for the supercharger (not talking about the heat exchanger in bumper).
Those are my $.02, take it for what it is worth.
Was it 35 degree's out ? I call bs endless you are running a chiller and methanold injection or your looking at coolant temp before you car is fully warmed up.
180s will break 175 intake temps with ease if its over 80 out
Heck, the other day I went from 40-100mph in 100* weather and I didn't touch 140* intake temps.
I'm running an EC heat exchanger and nearly pure water ( just a small amount of coolant for protection ). My pump is also always on ( apparently on some cars it's not but on mine it's always on ).
BTW- I said I don't touch 140 and looking back I did, it was 142* to be specific.
