Working on my launch.... track guys, I need help...."vid"
Every one here knows what I'm after. And the car has what it takes to get there. I' starting to think that it might be me holding the car back. Or maybe I'm just missing something some where. I need some help.
I've been back to the track four times now with the new trans. I've been to PBIR twice and County Line (1/8th mile) twice. Both times at PBIR I couldn't hook for sh*t. Even the first time at County Line I kept spinning through first gear. I'm not sure what I'm doing wrong. I never really had any problems hooking up before. What do you guys think will help my 60?
Last night was the first time it hooked. To bad I only got one run in. And like a dumb a*s I forgot to drop the psi in the tires. It was at 32 psi in the Hoosiers. I wonder what would have happened if i had lowered the psi.
This video is RedBullJnky vs JS Benz (E55 vs CL55).
I should be able to launch harder but I guess I'm just lost right now. Or maybe I'm just scared to brake another trans. I don't know.
'06 E55
I'm no expert on the subject, but I've got about 60-70 runs in. Are you brake-torquing (loading the converter up) at all? I left-foot brake, rev to 1100-1200, and on the third yellow I let off the brake and quickly (but not abruptly) apply the throttle. My 60' is merely decent, considering where I race, but my r/t's are pretty consistent using this method.
I'm sure some of the pro draggers here can fix or elaborate on this technique.
What is your usual PSI with those tires? How low can you go before it gets scary?
Next weekend or sooner Are you here?
I pretty much do all that. But the psi will vary from 12 - 18 depending on the track
Psi on the run from up top was 32. Normally it would be 15.
Thanks Dima!!!!
Here is the time slip from the vid. The tire pressure on this run was 32 psi. The CL55 ran 7.3 on a 1.8 '60.
'05 SL65, '13 FX4 Eco
Never raced my car with drags so I probably wont be much help... Not sure if you can smash it out of the whole or if you roll into the throttle. I know on streets I could only roll into it and Ive snapped out 1.8s with some decent prep. Track prep has so much to do with it. Are you going on street nights or track rentals? If you want your 10 go on a track rental day when they really load up the track. Also try for during the day sun might help hook better.
When I cut a 1.5x 60 ft, I had my pressure at 12lbs, burned out to the line, launch off idle, and put my foot through the floor. It will either hook or it wont, if it does not, try again.
I don't feather it or dilly dally around, if the track is prepped right, and you have the right tires with the correct pressure, you will hook. Get rid of those tires, and step up to MT ET Streets with no tube, it will take you and the car to the next level.
What suspension setting do you use? I know a few including me think the highest and softest setting allows the weight to shift back over the rear tires theoretically improving traction.
You might ask around as to which track is known for the best track prep. Where I used to live, IRP was know for ***** prep on Tuesday night street legals. However, a 90 minute drive to Muncie dragway on Wednesday nights always produced better 60s because the track owner kept the track well prepped. maybe you have a similar situation in south FL.
Like Chawkins says, a lot of guys launch from idle and go right to WOT. You either hook or you don't.
Dirt Scooters
Always launch in comfort mode,I use dyno mode always,DO NOT brake torque it or try to come up on the converter. What I found to work is after your staged torque it a little to raise the rear of the car then left off the gas. Wait for the lights and floor it. Either she hooks and your gone or it dosent and you let off and cruise down the track keeping her cooler becauae theres no sense in making a bad run in my opinion.
Dirt Scooters
Forgot to tell you to start tire pressure at 20lbs and go from there. My car is heavier so I actually went to 24lbs and found it worked better there when it was hot out. I've had them everywhere from 15lbs to 26lbs and I know 15lbs was way to low for my car. I spun the tire in the rim and the car would blow the tires off at the hit.
Sorry, Sorry, I'm a dumb a*s!!!
I always go around the water box. Then back into the water. Quick spin the tires to get them wet. Then pull up to do my burn out, then roll out of it.
The car is always in comfort (suspension), And i raise the car at the line. Then, depending on how the car feels, I will stall between 800-1200rpms. And when the third light hits I'll put the peddle through the floor and see if it hooks.
I keep the trans in M mode, because I like to controll the shift points. I shift at 6200rpms so that it drops back into peek tq, with out overheating. Once my meth gets back in order I will let it shift on its own.
I hope this will help get some answers. Thanks guys!
Was talking to an MB tech the other day. He told me even with ESP off, it will still control wheel spin, stabbing the brake on the side that loses traction. He said, essentially, ESP off will only remove throttle retardation. I suppose that is why I can produce enormously long and straight burnouts. So, if the E is the same as my SL, ESP off still causes the brakes to come on. This makes me think dyno mode just might deliver a 10th or two better run. Just be careful braking after you broke you PB.
Dirt Scooters
Launch off idle and it flashes the converter higher and seems to work best. Looking at your 1/8th mile pass you need to get it down in the 7.00's to have a good chance at a 10. Can't wait to see what it does with ice and meth.
1 Post
2008 ML63 2009 SL63 2010 Alpha 7 GTR
Wow 12lbs? Your nuts! That can't be safe bro.
1 Post
Ive never ran in Dyno mode or from idle curt.
Boom there it is ^^^^^^ how was the DA? The reason I ask is because for your mods your 1/8 mile speed is about 4-6mph low for what I have seen for a high 10sec E55. If the DA was good then you made need a slight tune adjustment
