hit me up if u have a 185 pulley
Looking to up the boost a bit so let me know what you got.
Looking for OEM Mercedes pulley with outer ring pressed on with no welds to throw the harmonics off the crank off.
I've done some new **** to the car and will make a thread soon.let's just say it feels like stock going to pulley tune on top on my current setup.
Iv tried k&ns,afes,new oem and no filters and this setup is as close to having no filters.I am using itg foam race filters and I cut 50% of the foam out
Here's me testing my custom air filters and fighting the car feathering the throttle trying not to break second loose @60 lol.
You can't really hear it but the sc whine is unreal!
https://www.youtube.com/watch?v=c0sS...e_gdata_player
Former Vendor of MBWorld
We have 2 stages of cut off if you can make the light blink with traction control off with it on it will do that like crazy.
I can make that light blink down the whole 1/4 mile even in 3rd and you can hear how aggressive the ecu is cutting throttle in the video.
Like Cory said when I was trying to get kleeman to 100% shut off traction control
If you can get that light to blink with the traction off button pressed your car is one bad **** and making ridiculous powa!
Dirt Scooters
well i had stupidly small filters on that were being sucked in if that makes any sense but the day before the pulley went we played with it on the dyno testing some nitrous stuff and found running 2 3.5 inch pipes into a a custom intake at the throttle body it picked up another 32hp over the filters and 15hp over no filters going into the custom ypipe that i usually run. The problem we had was it would come of the t/b to easy and didn't have enough holding it on. We planned to get more in depth with it but the pulley went and that was the end of it. Now there will be a 92mm replacing it with a pretty trick setup if the car is ever done.
2003 E55 & 2014 GL550
No wonder you are not running 10s bro, too much wheelspin!! You need full out super sticky drag slicks. I just can't believe how much wheelspin you get, even when you ran drag rads.
What a car!!! 185 pulley gonna make you spin in 5th. Lol
