Misfire
I guess it must be an air leak from the intake chambers because when I let the car idle on my driveway, I could hear a hiss sound, which I don't 'think' i've heard before. Can't be the plugs, but I won't rule them out. I'll give the wire connectors a secon push, to make sure' they're in.
What are the views on what this could be? Are we all thinking yep, it's down to a potential airleak. That to me would certainly explain the abnormally hot running of the engine/car.
actually ooooohhhhhhhhhhhhhhhhhhh of courrrseeeeeeee!!!! yep yep, that connects under the throttle body piping, right? Ahhh thanks so much man, I'm gonna check outside right now (lol it's nearly 1am here!)
However, I did notice that the red plastic cap thing which connects to a pipe which is best described as a kind of dipstick tube, was missing. I'm not referring to the one that is in clear view on top of the 'charger near the TB entry - I'm referring to the one under/behind the left throttle body pipe bend. This 'dipstick' bends under the firewall and leads towards the tranny.
Any more suggestions before I give up and take it to the local stealer?
Clearly a vac leak is not good but wondering how it works here on these cars.
So I bought a nice low range torque wrench, loosened the intake bolts then set about having them evenly torqued up. A few of them got torqued up nicely while for a few of them, the torque wrench decided to keep going past 20nm (well, it felt like more than 20nm, compared to the ones that it clicked on) and of course I broke one of my T30 Torx bits and when my friend brought over his one to enable me to complete the job, it ended up rounding 3 of the bolt heads off, but thankfully at least while they were very tight in the bore. I took it for a test run and the car sounded a helluva lot better without that unpredictable Impreza style idle wobbly sound. Power/response feels up too (maybe it was leaning out far too much before...I knew the car felt a bit sluggish!), but when I got home I gave it final test with the brake cleaner. I took the intakes off and sprayed around the gasket mating surface...all was well, but for one area, but of course I can't get the bolts loose again now, to re-tighten, SOooo I decided to use a very light layer of RTV around the mating surface. I hate to do it, but it's the simplest solution for the moment. I'll take it for a drive later on and report back with a further (and hopefully final!) update.
I decided to treat my car by giving it a tranny service at my local Indy, and tonight I drive around and feel some major wobble and jerky light load acceleration...then up comes the CEL on the dash and I'm like FML that damn vacuum leak won't die will it?!
Can somebody please post a pic of this metal pipe from the firewall that goes into the charger which I may have forgotten to connect? FYI new gaskets and bolts are on order from the Dealer, so hopefully that'll seal the manifold for sure when they arrive.
If there's no pipe that I've missed out, I can only hope that new gaskets and proper torqing is going to solve the problem. It's not nice having a car like this shake and wobble when you're out driving by yourself at night
Look again down here, there will be a black rubber grommet which faces the firewall. You might need a mirror to see it.
Before you changed the valve cover gaskets, there was a ~ 6mm metal pipe which was inserted into this grommet. This pipe also had a small bracket which attached to one the rear valve cover bolts. This pipe should be hanging behind the valve cover near the firewall. Good luck.
