Euroteck e63 Diffuser install suggestions
Bought this euroteck diffuser used from a member on here, but unfortunately, the screws that were attached to the diffuser to secure the install along with 3M tape aren't there anymore lol
What do yall suggest is the best way to install this diffuser on my car now?
All help is greatly appreciated and thanks in advance!
You may have to epoxy bolts on the diffuser from where they were broken off, if you don't do this no matter how much adhesive you put on the ends it will start coming off.
If you knew the bolts were broken before buying it then it is you head ache to fix it, but if you didnot then you should contact the seller
That's it ! I used the Gorilla Glue on the ends where the screws were. Then, I used plastic clamps to hold them snug until the glue dried. So far, it has held up very well.
Is that Marcus's old E55?
