Please:Need some help from the tire/alignment pros:)
Decided it was time to throw my 19" forged rims back on the beast.
I bought a set of slightly used Michelin PSS tires form a local member here.
On the first drive I had a VERY noticeable pull to the left under heavy acceleration. Once I jump off the gas the car "floats" back on track.
It honestly feels like the car is on ice! Punch the gas, darts left, lift off the gas, floats back in line straight. It is very disconcerting/scary.
I took the wheels/tires to a reputable shop by my house (Curry's) and had them mounted and road force balanced. Bought brand new conical seat lug bolts from RAD. The wheels were mounted and the lugs were torqued to spec by hand.
The car was aligned about a month ago, and I never noticed this trait with the 18" Conti DWS's.
Anybody have any thoughts as to what might be the issue?????
Thanks!
Brian
Obviously this doesn't explain anything if you never experienced the issue before... unless maybe your old tires were so rock-hard that they would never hook in the first place.
I was enjoying some wet pavement driving over the weekend, and did some 30MPH bursts. The rear tires (PSS's) would break loose and spin but I was also getting quite a bit of wheelhop which I think is also toe-in/toe-out related.
Subscribed to see what you end up finding out.
-G
Yes it may just be the change in tires, as the DSW are a hard, all season tire. I have experienced somewhat similar issues on other cars when upgrading tires/wheels, but nothing like this.
In fairness the issue is most prevelant on the highway when I pull hard in third...so there is over 550 ft lbs of torque to deal with at that point.
Do you guys think this might be exageratted by an improper alignment and if I get it re-aligned it will be minimized?
Who would have thought a vastly better and bigger tire would cause poor handling in any aspect of preformance....weird
Are you sure the rims and tires are perfectly true ? How about tire pressure - if the left tire is slightly lower in pressure, your car will pull under acceleration.
What happens when you brake hard (with little to no grip on the steering wheel) ?
I recently swap a set of 18" back on my car and experience some loose feeling in the rear. My car is lowered thru the elm, so raising the rear just one notch make the car feel a lot better.
Changing just tires and rims should not make a properly aligned car pull.
The car is lowered slightly with an elm.
I will check the air pressure, that's a good suggestion.
Shame on any installer who was that careless, but it's possible I suppose.
-G
Take your hands off the wheel when coasting and the car tracks dead straight.*
No vibration in the steering wheel at highway speeds
The right tire has 30psi and the left 32...probably not enough to have such a drastic effect.*
Honestly this feels like the torque steer I experienced driving a 500whp fwd Mazda I built. We nicknamed that car "the tree seeking missile" because when the big turbo spooled the power jerked the wheel towards the trees on the side of the road.*
One thing I did notice is that there is some vibration in the steering wheel under hard braking. Maybe the rotors are warped.????
Could the vibration under braking be something other than the rotors? Possibly leading to this problem?
I am stumped guys, so any help would be GREAT!
Thanks, Brian.*
Sometimes the shop goons will crank those lugnuts on WAAAY tighter than the normal spec (what is the correct spec for our wheels anyway....100Lb/Ft?) and can warp cause distortion in the rotor... maybe enough to cause a slight vibration like you described.
bstudey01: Good catch! Yes, I knew there was something to watch out for on the PSS (outside vs inside). I've been conditioned to look for the arrows for so many years, that advice became second-nature.
-G
Thanks, Brian.*
I will adjust the pressure and see if that helps. I will also return to the shop for there input and advice.
I seriously hope I can get this resolved, because the car looks great!
I think you need an alignment. I had mine done once, and they put the rears at zero toe-in. It felt like I was on ice when under heavy load.
Without LSD, the two side are fighting for control, and if you are at zero to toe out, the car will feel very unstable. I went back and explained this to the guy. He said: My computer shows zero toe is the correct alignment setting. I said get in.
After a quick run up onto the freeway, he gladly added .5 degree of toe in. Car is planted as before.
I tracked it down to the rear toe setting of my alignment, I had to use the MB Arts toe links to remedy the issue AND make sure your alignment thrust angle is perfect (as in 0.00 degrees).
I have been down with a tough leg infection the last week and have just got to resolving this isssue.
It turns out I should have checked the rear tire pressure as well (MORON!).
The drivers side rear valve stem was leaking. came out last Tuesday night after work and the tire was flat.
Replaced the stem. verified air pressure and VOILA...she is back to normal!
Still a very slight pull on hard acceleration, but nothing I cant live with until I get it realligned. May still do the camber arms and toe links, but at $1200 plus install I think I will try an alignment first.
Thanks again for all your hepl guys!
Brian
As for the vibration under braking, rotors, ball joints, and front torque thrust arms should be checked out.
