Another misfire thread, competant wrenchers opinions needed
Hang in there...only thing left is 02 sensor, since you have replaced/checked all of your igntion/fuel (plugs, wires, coil packs, injectors, corn fuel)
I am wondering if permanently turning off the rear o2's with the kleeman flash could cause this issue.
Could a bad map sensor or crank position sensor could be part of the problem too.
Three variables changed, new gas, new sensor with extended wires and kleeman flash for readiness. After that , the drivability has declined badly.
Usimng your words, and KNOWING your level of ability, look at the kleeman flash.
I KNOW you can solder wires correctly, and doubt the new sensor is bad, but it could be, aka slim chance.
Gas you know is good, along with coils, wires, etc, etc.
My money is on Kleeman. NOT that they are bad, but there could have been a hiccup.
GOOD luck
Failing that, my money would be on the 02 sensors as well.
Hope you get it sorted man. I literally know how you feel with this misfire
We did smoke tests, leak down, comp test, and nothing. So BIP drained out all the e85, took out the 1000cc injectors, and installed 550 inj along with 93 pump. BAM, the problem was gone. So both BIP and I got on the phone about the possible causes for this. I spoke to my local big mustang shop here in Atlanta who tunes fox bodys and cobras on E85 all the time. All I said is,"what are your thoughts about E85," and he hit the nail on the head. He said it is great for tuning, and makes copious amounts of power, but if you let the car sit for an extended period of time, they are seeing injectors seize up, and corrosion starting to occur. Fuel pumps are also taking a beating for the corrosion effects of the alcohol.
BIP has an engine builder there that has a vast amount of knowledge and big into the Subaru scene. The shop he came from builds high HP Subaru's, and they too love the E85, but they have also started to see corrosion and problems arising with the cheaper injectors. The tune will just start to break up from the corn, and this is due to failing injectors after sitting. That hit the nail on the head in my situation, as my car sat for a month after I got back from Timmayfest due to E85 not been produced. Given we changed absolutely nothing on the car from Columbus, the problem came up out of now where.
I am not going to say what style, model or make injectors I am using, but I am sending them back to get tested. It looks like I have three options here, go back to pump gas, drive the car regularly on E85 using the same injector, or go with a much more expensive injector that is more fail safe. As of right now I am not giving up on E85, as the car runs extremely hard when well.
Heck, I used it for years back in the 80's as a cheap octane booster, but NEVER more than 10%
Good luck!!
