Primary De-CAT
I'm thinking of putting everything back as it was
Do Kleemanns do a Primary De-CAT system?
If so how do they cope will the alarms?
or
should you NEVER remove the Primary CATS under any circumstances and leave the sensors where they are or you get the problems I'm encountering with no true solution
or
These headers also make good power for the price
From what you are saying the errors can definitely be removed. But I would still like to understand the function of the secondary sensors. Why Has the error code from my sensors caused the engine to run rich and consequently caused massive power reduction as seen on the dyno today ???? If its part of the management system and aids with the AFR's, how will the engine know what to do if they are mapped out or am I being thick?
The car is running poorly because you reconnected faulty sensors.
The cel can be easily shut off by those professionals that have experience with such things.
IE tuners like Kleeman.
There are some other fixes that are hard ware, and not software...but those required O2 sensors that are functioning within OEM spec.
Get the sensor shut of electronically and call it a day.
I am currently awaiting a call back from Kleemann UK
Well I consider the sensors and the wires as one unit, hence my comment that the sensors were not within spec..as in the don't work right.
Hope you get it resolved with minimal effort
