Sc inlet partnumber + y split
I gona upgrade to 82 mm throttle body, I do have 74 mm oe.
I have already an 82 throttle body a2731410325 But i do not have the cable from the body to the car harness. some one who have the part number so i can order it from the dealer ?
I have an 74 mm inlet and there are an 80 mm inlet, wich is better i suppose. Partnumber on that one please
or should i use the 74 and port the inlett to 84 ?? The y splitt does it comes from an new sl55 amg ? PLease partnumber on that one too.
thank ful for any help
82mm TB (MB)
A273-141-03-25
80mm Plenum
A113-140-09-12
Gaskets
A273-141-06-80 (Throttle Body)
A113-141-07-80 (Plenum to SC)
A113-098-00-80 (Right Intake)
A113-098-01-80 (Left Intake)
Y-Pipe Kit
A113 090 03 29 (Double check this.... )
A113 141 09 80 (x2) These are the gaskets which go between the s/c and head.
PS- Search 82mm TB and you will find a lot of good information. You could also buy a kit and save the headache
82mm TB (MB)
A273-141-03-25
80mm Plenum
A113-140-09-12
Gaskets
Y-Pipe Kit
