Stupid Seat Ventilators/coolers/whatever they are considered
Okay, so I know from reading around that these things barely do anything... So I put on some boxers and went out to my car at night and drove around with them on and I didn't feel anything but my sack sticking to my leg... Both sides don't appear to do anything other than cast a blue hue onto my shifter. Is it possible that there's a fuse blown? If so, where is the fuse located? Front SAM?
You could pull the cover off the seatbacks quite easily to visually confirm the fans are spinning.
There is a thread here about adding aftermarket fans to improve flow. I bought the fans but haven't done the swap yet. My fans spin but are almost undetectable...common complaint. New (upgraded) fans are reported to make a huge difference.
-G
-G
-G
-G
Some of us took it upon themselves to fix them:
https://mbworld.org/forums/4690299-post79.html
https://mbworld.org/forums/w211-amg/...seat-fans.html
I'm not sure if mine are the same in the SL, but I can hear the fan to the active seats running after shutdown prior to opening a door. I can only imagine they were designed to minimize shrivel factor during long drives on the autobahn considering German Climate. Not so effective in zonnie heat.
