Oem Sirius Sat install
Old Sep 3, 2012 | 06:56 PM
tbal's Avatar
Haters crazy
Picked up the oem unit, looking to add Sat to my car. To my understanding late model e55's were pre-wired? But guess I am wrong...
Whats need to install this bad boy? Went through the previous threads, cant seem to find something to do a full installation?
Only plug I see in the trunk, is this guy here...
Its a 4 prong female connector, does look like some audio plug...
Any info what be great!
Old Sep 3, 2012 | 07:23 PM
milepostnate's Avatar
2013 E63 Performance Package
It is really easy to do. I did a small write up on it a few years ago. You will find a link to the factory install directions there also.
https://mbworld.org/forums/w211-amg/...irius-diy.html
AMGPilot's Avatar
2004 E55
You are prewired, That's the plug. then you get a sirius microdot antenna and plug it into the SDAR box along with that plug, you will also need to include the SDAR in the MOST ring but that's easy since the adapter/closeout is already in the CTEL bay. The job can literally be done in less than 20 mins
Old Sep 3, 2012 | 07:46 PM
moosejaw's Avatar
none
Tony you can check my thread too
I think i posted the MOST ring diagram
Old Sep 3, 2012 | 07:59 PM
E55Dimon's Avatar
E63S
My man, don't bother. Wire in the auxiliary to the coin holder and stream ur fav radio. Sirius is old news.
Old Sep 3, 2012 | 09:10 PM
moosejaw's Avatar
none
Doesnt sound anywhere near the same quality. Aux is kind of so-so but better than a FM Modulator
Old Sep 4, 2012 | 01:38 AM
tbal's Avatar
Haters crazy
That pdf link is no longer working do you have a copy saved?
The plug does connect to the sat unit, is there some sort of adapter needed?
Figured why not try it
Old Sep 4, 2012 | 01:42 AM
tbal's Avatar
Haters crazy
Looked through you thread... still confused on if im pre-wired lol and what the heck that plug is... will take of the trunk liner on the hatch to see...
Old Sep 5, 2012 | 12:32 AM
tbal's Avatar
Haters crazy
anyone have the diy for a full installation for a car without pre wire?
Old Sep 5, 2012 | 08:35 AM
moosejaw's Avatar
none
So youre not prewired?
Ouch.
Old Sep 5, 2012 | 08:52 AM
slownrusty's Avatar
'06 E55 K2
Sadly....mid '05 and '06 cars are not pre-wired (on the MOST Ring), it is quite an undertaking to add Sirius on these model years. I looked into this on my '06 recently and have put this install on pause for the time being due to the effort required and little documentation.
Old Sep 5, 2012 | 11:41 AM
xpl0sive's Avatar
CLS55 AMG
Tony, I wouldn't bother. Get a Mobridge unit like I did. then you can stream music off your Iphone over bluetooth. It's really easy to install, but you do lose your CD changer. I have the ABT2010 model listed here
http://www.mobridge.us/products/most-bluetooth-ipod-aux
if you really want sat. radio, they have an XM radio version that you can run alongside the bluetooth/iphone module
http://www.mobridge.us/products/xm-satellite-radio
Old Sep 5, 2012 | 12:10 PM
moosejaw's Avatar
none
you guys are in canada, whats the point of satellite if you have the 50% Canadian content rule?
Thats means 5 out of 10 songs have to be one of the following
          and
            Old Sep 5, 2012 | 12:18 PM
            amg guy's Avatar
            2024 GLE 63 S Coupe 2020 E 63 S
            X2 the last of the e55's were not pre wired. I have a early 05 and luckily it was prewired. I installed all of the parts into my car from the truck, nothing in the car. I did install the antenna on top of the truck for the factory look. drilling a hole in the trunk was less than exciting.... But its done and I use my sirius radio every time I drive. It took me about 2 hours going slow and careful as the truck panels have to come out and drilling the hole in the trunk.
            Old Sep 5, 2012 | 01:32 PM
            moosejaw's Avatar
            none
            Dude you drilled your trunk?
            hopefully you used a smaller painted antenna receiver?
            Old Sep 5, 2012 | 02:04 PM
            amg guy's Avatar
            Yes, All oem parts, the trunk actually has a spot specifically made for that antenna. It is the small OEM one. It was ordered with the correct paint color from benz. No shortcuts here. I read plenty of problems with antenna interference with the deck lid installs.
            The large OEM is well, hideous. But since they have the new style which is painted to match the car and 1/10 the size. Doesn't bother me a bit.
            Guy complain about this antenna still but put hideous other parts on their cars?
            Guess it's up to the owners likes or dislikes.
            Old Sep 5, 2012 | 03:00 PM
            moosejaw's Avatar
            none
            the second generation antenna i could live with
            My buddy C55asleep? had the cockroach on the back of his trunk. look how big that think was. And he didnt he even like the satellite radio because they didnt play "Miami Freestyle"
            Old Sep 5, 2012 | 03:25 PM
            amg guy's Avatar
            Ouch that one is bad. This one is the one I'm talking about. This is just an image I found on google.
            Old Sep 6, 2012 | 06:30 AM
            c50bart's Avatar
            2006 E55 AMG
            Factory Satellite Install
            Hey guys. New to the forum and having a bit of trouble with the Sirius factory install. I was hoping someone could enlighten me.
            I installed a 04 Sirius unit with splitter and antenna in my 2006. I connected the 4 pin 2 optic connector and the splitter came to me with both white & blue connected to unit so I assume that the antenna hooked up to the splittler. I have two connecter hanging near the unit that are white and blue with foam wrapped on them.
            1 - Are these used with the sirius?
            My second hurddle is the comand unit says No Satellite radio when I press the Sat button.
            2 - Do I have to program the comand to see/recognize the sirius module?
            If anyone could actually explain in detail the correct wiring install so I can make sure I hooked it up correctly that would be awesome.
            I'm also considering the factory phone bluetooth setup for the iphone. Any input or advice on factory or aftermarket? I'm looking to take full advantage of the cars accessories.
            Chris..
            Old Sep 6, 2012 | 08:29 AM
            moosejaw's Avatar
            none
            Make sure your antenna connection is snug, the mercedes sat unit has its own antenna connection which is incompatible with a pioneer antenna. YOu would have to modify it to accept a pionner antenna.
            There is a write up here on how to connect an I-Phone to OEM phone system.
            You do not have to program the command to receive a satellite module.
            Are you sure your prewired. I dont think mentioned going into the trunk to connect the satellite unit to the audio gateway?
            Old Sep 6, 2012 | 09:01 AM
            c50bart's Avatar
            2006 E55 AMG
            I modified a Sirius sat antenna to fit splitter. 3M Taped on the trunk with 3" of space off rear glass.
            I don't have any components for bluetooth/phone system. Shopping that soon.
            Prewired yes but connections are questioned. {4pin/2 optic is plugged in and white and blue antenna w/foam wrap are just hanging near module. Splitter is plugged into white and blue on module and antenna is plugged into splitter.
            Audio gateway??
            Links to threads would be greatly appreciated.... Searched so much eye ***** want to pop..
            Old Sep 6, 2012 | 10:34 AM
            tbal's Avatar
            Haters crazy
            I have this Sirius sat module for sale of anyone wants it...
            Old Sep 6, 2012 | 12:12 PM
            moosejaw's Avatar
            none
            Originally Posted by c50bart
            Audio gateway??
            Audio gateway requires the most work. if you are prewired you will have to remove rear trunk panel wayyyyy in the back of the trunk and find the yellow connector(s), unplug it and join the orange connector in between.
            Once this is done you will be able to see your Sirius Unit on the Command.
            Old Feb 10, 2014 | 12:36 PM
            USMCR O-5's Avatar
            2007 GL450, 2005 E320, 2000 E320 4Matic
            This is a great post and I've installed a used OEM Sirius unit in my 2005 E320. My question is the fiber optic connector into the MOST ring. How are the fiber optic connectors used? Do you "pull" the cable out of the connector or do you open the connector up some how to insert the cable? I don't want to damage any of it and this is the first time I've used fiber optic. Thanks.
            Old Feb 10, 2014 | 12:42 PM
            shardul's Avatar
            Former Vendor of MBWorld
            2003 W211 E55, 2003 W220 S600
            open the connector
