split update
Old Sep 9, 2012 | 09:18 AM
99lightning's Avatar
99 ford lightning
split update
temps were around 58-60deg this am i did a pull looks like act started off at around 64 deg and hit around 125 by the time i shut the record button off out of throttle mind you 143deg. my speed was 119mph so i think it was in 4th gear it took no time to get the cruising temps at 45-50mph around 80deg. then on the high way did a pull from 60-110mph temps stared in the low 80's and and rose to about 110deg and 125 out of the throttle. in a rush off to the track 4dr ford fairmont ls1 80mm i just washed my car so its going to get parked.
Old Sep 9, 2012 | 10:37 AM
Bramage's Avatar
F-250
Good update, and IAT's are looking good.
After you wash car, you go pick up chicks.. not park.
Could not quite make out the track sentence, but if you are racing, good luck!
Old Sep 9, 2012 | 04:54 PM
99 ford lightning
nope rode down in a ford fairmont. still a little hot out for drag racing for me.
