Old Jun 15, 2015, 07:46 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Electrical Guides
Print Wikipost
Replacing O2 sensors
Old Sep 12, 2012 | 12:46 AM
hollandca12's Avatar
Hello all,
Recently I have been having recurrent issues with p0135 code popping up. My OBDII scanner is signaling a faulty Bank 1 O2 sensor which I believe is on the left front sensor. I'm thinking about trying to tackle this one myself, but if it seems to difficult or laborious I may drop it off at the dealer for a warranty repair.
Anyone have any helpful diagrams or DIYs out there on sensor replacements? And yes I did search......
Thanks in advance
Courtney
Old Sep 12, 2012 | 04:15 AM
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
It should say Sensor 1 or Sensor 2 as well and Bank 1 or Bank 2.
Sensor 1 is the one before the catalytic converter closer to the engine, and Sensor 2 is after the catalytic converter.
Bank 1 is the passenger* side. (Edited this to correct it)
They should all be pretty straight forward to replace but you're gonna need the car on jack stands or a lift.
Old Sep 12, 2012 | 06:51 AM
benzmodz's Avatar
W203 slightly modified
I highly recommend you purchase the tool attachment to your ratchet which helps remove the sensor. Its cheap and it makes the job much easier.
http://www.hcb-autotools.com/compone...d,26/vmcchk,1/
Old Sep 12, 2012 | 09:57 AM
vioilio's Avatar
2003 E55 AMG
Bank 1 is actually the passenger side. Just find out if it is the Sensor 1 (pre-cat) or Sensor 2 (post cat). Replacement is easy. Make sure you use some anti seize compound on the thread IF the new sensor does not already have it.
Old Sep 12, 2012 | 12:59 PM
Bramage's Avatar
F-250
Bank 1 is passenger side.
As stated, you need to know if O2 #1 (Upstream) or O2 #2 (Downstream)
Old Sep 12, 2012 | 04:46 PM
ALLDATAdiy INFO's Avatar
Former Vendor of MBWorld
Mercedes
Alldatadiy.com has repairs at your fingertips! Good luck with your job of fixing your vehicle!
Old Sep 12, 2012 | 10:15 PM
Its the Bank 1 Sensor 1; Is this sensor accessible from the engine bay or will i need the jack stands as you mention.
Thanks for the info guys
