Need help with battery drain, got star scanned what does this code mean?
Old Oct 4, 2012 | 12:20 AM
kompressorfed's Avatar
MB
So I've had a battery problem that was diagnosed as a small drain. After star diagnostics my Indy shop gave me this code, code 3002 control unit n93 defective (central gateway control unit). So this is the central gateway module and not the audio gateway? I know 03had agw modules go faulty but I guess this is not my case? Anyone have current part #'s for this?
Old Oct 4, 2012 | 04:48 AM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
You will need to provide your VIN to MB for the proper #
Old Oct 4, 2012 | 06:58 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
It costs about $120 new and is located under the driver side dash
Old Oct 4, 2012 | 07:59 AM
benzmodz's Avatar
W203 slightly modified
It is a small black box the size of a sardine can. It helps manage the traffic between different data networks in the car.
In later years it was integrated into the ignition switch. So in those cars you must obtain a new ignition switch.
Don't know the code but you can google "OBD code P3002" and see what you get.
Old Oct 4, 2012 | 08:02 AM
benzmodz's Avatar
It appears that 3002 means your gas pedal is not working well. Is there some damage to the wiring in that area because they appear to be close to each other in the car.
Start looking for primary causes. Seems odd.
