Built Transmission
Old Oct 4, 2012 | 08:22 PM
Triman2008's Avatar
S55 AMG
Built Transmission
Hey guys.....I'm posting in the W211 becasue everyone knows the W220 section is slow. I have a question......Does anyone know where I can get me transmission rebuilt to hold the power I have.....also looking at doing either the Weistec blower kit, or the Speedriven kit when that becomes available. Just looking to get ideas from all of you before I move forward with this project.
Does anyone have numbers from the what Weistec kit puts down on our engines? Seems that they have done a lot of testing with the 63's and not a whole lot with our platform. Thanks in advance.
Old Oct 4, 2012 | 08:50 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Southern hotrod transmissions have good reviews
Old Oct 4, 2012 | 09:06 PM
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
The sad thing is Weistec doesn't know what it'll do on our engines
Old Oct 4, 2012 | 09:57 PM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
Speedriven builds transmissions as well, when there supercharger is finished maby they'll give you a package deal they hold up to the stupid torque numbers on there gt30 v12's
Old Oct 4, 2012 | 10:26 PM
Triman2008's Avatar
S55 AMG
I read that about Speedriven, but I didn't think it was for the 722.6 trans. I will have to look in to that.
Shardul, who is this Southern Hotrod Transmission?? Have they done built transmissions for AMG's?
Old Oct 4, 2012 | 10:35 PM
Shifter's Avatar
E55, SL63, ML550
The V12 s use the 722.6
Old Oct 5, 2012 | 07:54 AM
cij911's Avatar
one car at a time
Here are a few :
Here are a few other options :
http://paramountperformanceproducts.com/
http://www.rennhausautorepair.com/tu...ission-upgrade
http://iptperformancetransmissions.wordpress.com/
Old Oct 5, 2012 | 08:25 AM
Triman2008's Avatar
S55 AMG
Thanks you guys, for all the info. This is what I'm talking about. The W220 section is dead for performance. You guys know where it's at. Thanks again.
Old Oct 5, 2012 | 08:26 AM
shardul's Avatar
Yes sir
Old Oct 5, 2012 | 11:16 AM
blackbenzz's Avatar
haters crazy
I've run a southern hot rod Trans for years. I also installed a paramount performance Trans for a friend and was good too. Is your current transmission bad? I have also tested IPT valve body and torque converter
Old Oct 5, 2012 | 04:20 PM
Triman2008's Avatar
S55 AMG
I think so, my car goes into limp mode whenever I go over half throttle. No noise or grinding, just feels like the throttle won't go over half. It just recently started doing this. If you go WOT it will go full throttle for like 2-3 sec, then it will chop the throttle to less than half.
Old Oct 5, 2012 | 04:36 PM
shardul's Avatar
Do you get a CEL when the car goes into limp mode?
Old Oct 5, 2012 | 05:02 PM
Triman2008's Avatar
S55 AMG
CEL has been on. I think it's because of the 82mm TB I have a CEL. The car runs just fine, idles fine and even under WOT it runs great......just the limp mode.
Old Oct 5, 2012 | 05:31 PM
shardul's Avatar
read the codes there may be more than the ones related to the 82mm
Old Oct 5, 2012 | 05:38 PM
betrezra's Avatar
C63 507 AMG DA Car #19
Shardul knows..... also see what STAR DAS machine says. GL.
I have a southern hotrod trans in my future.
Old Oct 5, 2012 | 05:42 PM
Triman2008's Avatar
S55 AMG
I don't have anything to read codes with......
Old Oct 5, 2012 | 05:47 PM
PACougar's Avatar
No offense but I wouldn't consider purchasing a transmission before you have any idea of what's actually wrong. Your problem might be relatively cheap and easy to fix.
Old Oct 5, 2012 | 05:56 PM
Triman2008's Avatar
S55 AMG
Yes, I completely agree with you. I will get the codes read, and see if there is anything else before I o down that road. Mainly I wanted to know if there were people out there that did do aftermarket work on AMG Transmissions.
I had someone pm me thinking it was m intercooler pump. I don't believe it to be the pump, but I will check it.
Old Oct 5, 2012 | 06:43 PM
betrezra's Avatar
Yup.. could be bad i/c pump..... codes are your friend. MB STAR DAS is your BEST Friend
I would invest in a good knock-off. GL.
Old Oct 7, 2012 | 08:14 AM
Triman2008's Avatar
S55 AMG
How much does a STAR DAS run???
Old Oct 7, 2012 | 10:35 AM
stockC43's Avatar
A china/eBay one about $500. Might last a year before it craps out. A good German one about $2500+. A real mb one, $27,000! You can also go the snap-on way and that would be $1000+ for a nice used one. The mb style ones work best though.
I agree with running codes though. Why buy a trans if it's only a $100 conductor plate
Btw I've been running a builder bill/paramount trans for 4 years and it holds up to my abuse but it down shifts like sh** when coming to a stop. I may put in brown top soloniods to soften the down shifts.
