Shardul Hit it on the Head
Been Complaing about the grindig Noise from my rear suspension
And it turns out that my rear sub frame bolt snapped off![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
Just like shardul said thanks man
Pass rear
![](http://i21.photobucket.com/albums/b284/jamy123/6B31CFE3-0FD7-41E4-8029-CC20E72DF4A3-315-00000011978EF0C5.jpg)
Driver rear
Pass rear
Driver rear
![](http://i21.photobucket.com/albums/b284/jamy123/D32C17F5-06B4-4C9B-9A00-20F54223E4AB-315-00000011940B58FC.jpg)
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
I have seen the symptoms you had mentioned on countless E and CLS class
Drill the old bolt out, the nut is welded onto the chassis and it will be use less since the threads will get messed up when you drill it out. Use a longer bolt and nut assembly. You will have to cut some sheet metal to thread the nut in on the longer bolt.
1 hr job if you have the right tools
Quick suggestion brahhh... I say buy the left side one too so both are new.... I think am going to buy two as well and swap em to new just prventive maitinance. I mean 4$ each aint gona hurt
1 Post
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
This might be part of my upcoming maintenance i have to do. I am going to pass the part number over to my indy shop. I assume these bolts get loctite unless there is a lock washer on them i cannot see?
Aaron
Aaron
thxx man
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
2005 E55 AMG
For those that have modded cars and have not sheared off the bolt, I wonder if simple replacement would be a good preventative maintenance.
I assume the bolt is under repeated heavy load which ultimately leads to failure. Given these cars are now 7+ years old, maybe its a good call to replace every 5 -6 years just to be safe? -And while they are still removable![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
0029907422 looks like the part is around $4 ea
Will do mine over the weekend. They are $2.28ea @ parts.com
change out all 4 bolt, not just the 2 on the rear portion of the subframe.
Now of the bolts are strong the chassis mounting points are also know to tear so if this happens in the future you all are looking to spend major money to fix.
![](http://imageshack.us/a/img155/1063/img0450yl.jpg)
